Your Portal Version: 2.0.2
Boardlink: http://killinzedz.vilayer.me/phpbb/
N/A
N/A
How do I add a link to the Portal at the top of the page? There's a link to the Board Index, but once you are in the forums, there's no link to go back to the portal.
Adding portal link
Re: Adding portal link
Nevermind. I figured this out after translating some other posts from German to English.
- phpBB.de User: Kirk
Open the install.xml and follow the instructions there.BetterDeadThanZed wrote:How do I add a link to the Portal at the top of the page?
What do you have for a Style?
I already figured it out. Thanks for the reply.Kirk wrote:Open the install.xml and follow the instructions there.BetterDeadThanZed wrote:How do I add a link to the Portal at the top of the page?
