SE Gamer Dark issue
BetterDeadThanZed
SE Gamer Dark issue
Post by BetterDeadThanZed »
Your Portal Version: 2.0.2
Boardlink: http://killinzedz.vilayer.me/phpbb/
Nothing. I installed a fresh PHPBB and then this happened
Nothing. I don't know what to do.
I just installed this forum package, followed by the portal, and finally with the style SE Gamer Dark, found here: viewtopic.php?f=57&t=10646
There are white boxes on the sides, as you can see from the link to the website. How do I fix this so the boxes aren't white, so they match the rest of the theme?
Re: SE Gamer Dark issue
Open: root/styles/SE Gamer Dark/theme/colours.css
Find:
ul.forums {
   background-color: #262626;
Replace with:
ul.forums {
This is also in the instructions.
BetterDeadThanZed
Thank you for the reply. I didn't see that in the instructions so I apologize. It's looking good now. :)
BetterDeadThanZed
I have another issue now. I installed the donate mod (https://www.phpbb.com/customise/db/mod/ ... ation_mod/). The topic says it's compatible with 3.0.12. When I install it with SE Gamer Dark from these forums, the portal's font gets larger. I'm still relatively inexperienced in PHPBB3 and I just started using board3, so please forgive me if the answer is obvious. :)
I'm attaching screenshots showing what it looks like with the donation mod and without it. The top screenshot shows the font too big.
This is not a Portal problem, please question the Moder on phpBB.com
BetterDeadThanZed
Kirk wrote:This is not a Portal problem, please question the Moder on phpBB.com
It only happens on the portal page, not on the forums.
We do not provide support to other mods.
Return to “Styles Support”
