Team block
Current Version: 2.0.2
Released: 2013-10-27
Paul
Team block
Post by Paul »
Boardlink: http://britishcelebrityfakers.co.uk/portal.php
Hello
I have been trying to alter the team block so it shows the staff on my forum.
Admin
Global moderators
Archive moderators
I did a search and found this https://www.phpbb.com/customise/db/mod/ ... 70#p247170
after following the instructions I get the admin and moderators showing but underneath I see the following text
Archive moderators
NO ARCHIVE MODERATORS
These are my edited files.
leaders_side.html:
	<strong<!-- IF S_CONTENT_DIRECTION eq 'rtl' --> style="float: right;"<!-- ENDIF -->>{L_ADMINISTRATORS}</strong><br />
	<!-- BEGIN admin -->
		<span style="float:<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->right<!-- ELSE -->left<!-- ENDIF -->;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /></span><span style="<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->float:right; padding-right:5px;<!-- ELSE -->float:left; padding-left:5px;<!-- ENDIF --> padding-top:2px;"><strong>{admin.USERNAME_FULL}</strong></span><br style="clear:both" />
	<!-- BEGINELSE -->
		{L_NO_ADMINISTRATORS_P}<br /><br />
	<!-- END admin -->
	<strong<!-- IF S_CONTENT_DIRECTION eq 'rtl' --> style="float: right;"<!-- ENDIF -->>{L_MODERATORS}</strong><br />
	<!-- BEGIN mod -->
		<span style="float:<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->right<!-- ELSE -->left<!-- ENDIF -->;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /></span><span style="<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->float:right; padding-right:5px;<!-- ELSE -->float:left; padding-left:5px;<!-- ENDIF --> padding-top:2px;"><strong>{mod.USERNAME_FULL}</strong></span><br style="clear:both" />
	<!-- BEGINELSE -->
		{L_NO_MODERATORS_P}
	<!-- END mod -->
   <strong>{L_ARCHIVE MODERATORS}</strong><br />
   <!-- BEGIN arc -->
      <span style="float:left;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /></span><span style="float:left; padding-left:5px; padding-top:2px;"><strong>{col.USERNAME_FULL}</strong></span><br style="clear:both" />
   <!-- BEGINELSE -->
      {L_NO_ARCHIVE MODERATORS_P}
   <!-- END arc -->
root/portal/modules/portal_leaders.php:
'WHERE'        => 'u.group_id = g.group_id AND ' . $db->sql_in_set('g.group_name', array('ADMINISTRATORS', 'GLOBAL_MODERATORS', 'ARCHIVE_MODERATORS')),
				'ORDER_BY'	=> 'g.group_name ASC, u.username_clean ASC'
and
				if ($row['group_name'] == 'ADMINISTRATORS')
					$which_row = 'admin';
				elseif ($row['group_name'] == 'GLOBAL_MODERATORS')
					$which_row = 'mod';
				                elseif ($row['group_name'] == 'ARCHIVE_MODERATORS')
                    $which_row = 'arc';
root/language/en/portal_leaders_module.php:
'NO_ADMINISTRATORS_P'	    => 'No Administrators',
	'NO_MODERATORS_P'		    => 'No Moderators',
	'NO_ARCHIVE_MODERATORS_P'   => 'No Archive Moderators',
	'NO_GROUPS_P'			    => 'No Groups',
	'ACP_PORTAL_LEADERS'	    => 'The Team',
and
'PORTAL_LEADERS_EXT_EXP'	=> 'The standard block lists all admins/mods/Archive moderators, while the extended block includes all non-hidden groups with a legend.',
root/language/en/common.php:
'AND'							=> 'And',
    'ARCHIVE_MODERATORS'            => 'Archive moderators',
	'ARE_WATCHING_FORUM'			=> 'You have subscribed to be notified of new posts in this forum.',
and
'G_ADMINISTRATORS'			=> 'Administrators',
	'G_ARCHIVE_MODERATORS'      => 'Archive moderators',
	'G_BOTS'					=> 'Bots',
I think I have gone wrong with the Capitals and or shortening Archive moderator ?
Thanks in advance
Paul[/i]
Re: Team block
Open: root/styles/your_style/template/portal/modules/leaders_side.html
Find;
Replace with:
{L_NO_ARCHIVE_MODERATORS_P}
Open: root/language/en/common.php
Find:
Replace with:
'ARCHIVE_MODERATORS_P'            => 'Archive moderators',
Paul
Re: Team block
Post by Paul »
Hi Kirk
Did those edits and now get this under the global moderators names....
Paul
Re: Team block
Post by Paul »
Hi Kirk
I found I missed changing col to arc in the leaders_side.hmtl
{col.USERNAME_FULL}
All is good now, many thanks for the help you have given.
