Your Portal Version: 1.0.2
Boardlink: http://www.phpbbhosts.co.uk/support
Install version 1.0.2
Nothing yet
Hi all i have just installed version 1.0.2 and logged into my ACP to find two tabs one that is titles .mod which seems to have all correct sub menus and portal tab that seems to be missing the last couple of sub menus why is this?
I did used to have phpb3portal installed so maybe the portal tab was from that should i just remove the portal tab?
I have also just noticed that although you can turn all boxes off you can not actually turn the portal off as you just get the blank portal page i would love to be able to turn the whole portal on/off so that when it is off visitors/users will be directed to the normal board index and when portal is on visitors/users are directed to the portal page. how could i achieve this?
Admin panel trouble
Admin panel trouble
http://www.gpedz.co.uk
Forum promotion as it should be
Re: Admin panel trouble
Ok sorry guys i figured out that the portal tab was left over from the old portal So what i would like to know now is the following:
How can i change the tab name .mod to portal?
And
And
