Your Portal Version: 2.0.1
I noticed that you had in the update instructions of v2.0.1 to v2.0.2 to also replace the portal.php file, but I noticed that there is no changes made to that file between v2.0.1 and v2.0.2?
I am just wondering if in case you missed providing the update version to the installation file on phpbb.com download?
portal.php between 2.0.2 vs. 2.0.1
MOB
- phpBB.com User: M.O.B.
