navigation bar problems
hyperboy
Post by hyperboy »
Boardlink: http://2fsklan.com/
PHP Version: 3.0.2
I'm using X-Treme red template for my forums and i just recently installed board3's portal and i cannot get the nav to work right, istead of being "Portal>Board Index" it only sais "Board indext" But the portal does work when you first join the site, please take a look at it "http://www.2fsklan.com/forum/"
Then say here is my overall_header.html
<head>
{META}
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
var perpage = '{PER_PAGE}';
* Find a member
function find_username(url)
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
</script>
<SCRIPT TYPE="text/javascript">
// copyright 1999 Idocs, Inc. http://www.idocs.com/tags/
// Distribute this script freely, but please keep this
// notice with the code.
var rollOverArr=new Array();
function setrollover(OverImgSrc,pageImageName)
if (! document.images)return;
if (pageImageName == null)
pageImageName = document.images[document.images.length-1].name;
rollOverArr[pageImageName]=new Object;
rollOverArr[pageImageName].overImg = new Image;
rollOverArr[pageImageName].overImg.src=OverImgSrc;
function rollover(pageImageName)
if (! rollOverArr[pageImageName])return;
if (! rollOverArr[pageImageName].outImg)
rollOverArr[pageImageName].outImg = new Image;
rollOverArr[pageImageName].outImg.src = document.images[pageImageName].src;
document.images[pageImageName].src=rollOverArr[pageImageName].overImg.src;
function rollout(pageImageName)
document.images[pageImageName].src=rollOverArr[pageImageName].outImg.src;
</SCRIPT>
</head>
<a name="top"></a>
<div id="wrapheader">
	<table id="bx" width="100%" border="0" cellpadding="0" cellspacing="0">
			<table id="bx" width="100%" height="40" border="0" cellpadding="0" cellspacing="0">
				<td><img src="{T_THEME_PATH}/images/header/h11.png" width="40" height="40" alt=""></td>
				<td><img src="{T_THEME_PATH}/images/header/h12.png" width="100" height="40" alt=""></td>
				<td background="{T_THEME_PATH}/images/header/h13.png" width="100%" height="40">
				<td><img src="{T_THEME_PATH}/images/header/h14.png" width="100" height="40" alt=""></td>
				<td><img src="{T_THEME_PATH}/images/header/h15.png" width="40" height="40" alt=""></td>
			<table id="bx" width="100%" height="140" border="0" cellpadding="0" cellspacing="0">
				<td><img src="{T_THEME_PATH}/images/header/h21.png" width="40" height="140" alt=""></td>
				<td><img src="{T_THEME_PATH}/images/header/h22.png" width="100" height="140" alt=""></td>
				<td background="{T_THEME_PATH}/images/header/h23.png" width="100%" height="140">
					<div id="logodesc">
				<td><img src="{T_THEME_PATH}/images/header/h24.png" width="100" height="140" alt=""></td>
				<td><img src="{T_THEME_PATH}/images/header/h25.png" width="40" height="140" alt=""></td>
			<table id="bx" width="100%" height="66" border="0" cellpadding="0" cellspacing="0">
				<td><img src="{T_THEME_PATH}/images/header/h31.png" width="40" height="66" alt=""></td>
				<td><img src="{T_THEME_PATH}/images/header/h32.png" width="100" height="66" alt=""></td>
				<td background="{T_THEME_PATH}/images/header/h33.png" width="20%" height="66" align="center">
					<A HREF="{U_INDEX}"
					onMouseOver = "rollover('home')"
					onMouseOut = "rollout('home')"
					<IMG SRC="{T_THEME_PATH}/images/buttons/home1.png"
					NAME="home"
					ALT="Home Page" BORDER=0
					HEIGHT=40 WIDTH=101
					</A>
					setrollover("{T_THEME_PATH}/images/buttons/home2.png");
					</SCRIPT>
					<A HREF="{U_FAQ}"
					onMouseOver = "rollover('faq')"
					onMouseOut = "rollout('faq')"
					<IMG SRC="{T_THEME_PATH}/images/buttons/faq1.png"
					NAME="faq"
					HEIGHT=40 WIDTH=101
					</A>
					setrollover("{T_THEME_PATH}/images/buttons/faq2.png");
					</SCRIPT>
					<!-- IF not S_IS_BOT -->
						<A HREF="{U_TEAM}"
						onMouseOver = "rollover('team')"
						onMouseOut = "rollout('team')"
						<IMG SRC="{T_THEME_PATH}/images/buttons/team1.png"
						NAME="team"
						HEIGHT=40 WIDTH=101
						</A>
						setrollover("{T_THEME_PATH}/images/buttons/team2.png");
						</SCRIPT>
					<!-- IF S_DISPLAY_SEARCH -->
						<A HREF="{U_SEARCH}"
						onMouseOver = "rollover('search')"
						onMouseOut = "rollout('search')"
						<IMG SRC="{T_THEME_PATH}/images/buttons/search1.png"
						NAME="search"
						HEIGHT=40 WIDTH=101
						</A>
						setrollover("{T_THEME_PATH}/images/buttons/search2.png");
						</SCRIPT>
							<A HREF="{U_MEMBERLIST}"
							onMouseOver = "rollover('members')"
							onMouseOut = "rollout('members')"
							<IMG SRC="{T_THEME_PATH}/images/buttons/members1.png"
							NAME="members"
							HEIGHT=40 WIDTH=101
							</A>
							setrollover("{T_THEME_PATH}/images/buttons/members2.png");
							</SCRIPT>
				<td background="{T_THEME_PATH}/images/header/h33.png" width="100%" height="66"></td>
				<td><img src="{T_THEME_PATH}/images/header/h34.png" width="100" height="66" alt=""></td>
				<td><img src="{T_THEME_PATH}/images/header/h35.png" width="40" height="66" alt=""></td>
<div id="wrapcentre">
			<table id="bx" height="45" border="0" cellpadding="0" cellspacing="0" align="center">
				<td><img src="{T_THEME_PATH}/images/p_menu/p_01.png" width="61" height="45" alt=""></td>
				<td background="{T_THEME_PATH}/images/p_menu/p_02.png" width="20%" height="45"></td>
				<td><img src="{T_THEME_PATH}/images/p_menu/cu_l.png" width="44" height="45" alt=""></td>
				<td background="{T_THEME_PATH}/images/p_menu/cu_m.png" width="20%" height="45" align="center">
					<h5>
							<!-- IF S_USER_LOGGED_IN -->
								<!-- IF S_DISPLAY_PM --> &nbsp;<a href="{U_PRIVATEMSGS}"> {PRIVATE_MESSAGE_INFO}
									<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}
									<!-- ENDIF --></a>
							<!-- ELSEIF S_REGISTER_ENABLED --> &nbsp;<a href="{U_REGISTER}"> {L_REGISTER}</a>
					</h5>
					<h5>
							<a href="{U_LOGIN_LOGOUT}"> {L_LOGIN_LOGOUT}</a>&nbsp;
						<!-- IF U_RESTORE_PERMISSIONS --> &nbsp;<a href="{U_RESTORE_PERMISSIONS}"> {L_RESTORE_PERMISSIONS}</a>
						<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --> &nbsp;<span style="color: red;">{L_BOARD_DISABLED}</span>
					</h5>
							<h5>
								<a href="{U_PROFILE}"> {L_PROFILE}</a>
							</h5>
				<td><img src="{T_THEME_PATH}/images/p_menu/cu_r.png" width="45" height="45" alt=""></td>
				<td><img src="{T_THEME_PATH}/images/p_menu/p_03.png" width="61" height="45" alt=""></td>
			<table id="bx" height="45" border="0" cellpadding="0" cellspacing="0">
				<td><img src="{T_THEME_PATH}/images/p_menu/p_08.png" width="61" height="45" alt=""></td>
				<td background="{T_THEME_PATH}/images/p_menu/p_85.png" width="100%" height="45">
								<td background="{T_THEME_PATH}/images/p_menu/p_85.png" width="10%" height="36" align="center">
									<A HREF="{U_SEARCH_UNANSWERED}"
									onMouseOver = "rollover('search_unanswered')"
									onMouseOut = "rollout('search_unanswered')"
									<IMG SRC="{T_THEME_PATH}/images/buttons/ut1.png"
									NAME="search_unanswered"
									ALT="{L_SEARCH_UNANSWERED}" BORDER=0
									HEIGHT=36 WIDTH=150
									</A>
									setrollover("{T_THEME_PATH}/images/buttons/ut2.png");
									</SCRIPT>
									<A HREF="{U_SEARCH_ACTIVE_TOPICS}"
									onMouseOver = "rollover('search_active')"
									onMouseOut = "rollout('search_active')"
									<IMG SRC="{T_THEME_PATH}/images/buttons/at1.png"
									NAME="search_active"
									ALT="{L_SEARCH_ACTIVE_TOPICS}" BORDER=0
									HEIGHT=36 WIDTH=150
									</A>
									setrollover("{T_THEME_PATH}/images/buttons/at2.png");
									</SCRIPT>
								<td align="center" width="60%">
									<!-- IF S_USER_LOGGED_IN -->{LAST_VISIT_DATE}
											<A HREF="{U_SEARCH_NEW}"
											onMouseOver = "rollover('search_new')"
											onMouseOut = "rollout('search_new')"
											<IMG SRC="{T_THEME_PATH}/images/buttons/np1.png"
											NAME="search_new"
											ALT="{L_SEARCH_NEW}" BORDER=0
											HEIGHT=36 WIDTH=150
											</A>
											setrollover("{T_THEME_PATH}/images/buttons/np2.png");
											</SCRIPT>
											<A HREF="{U_SEARCH_SELF}"
											onMouseOver = "rollover('search_your')"
											onMouseOut = "rollout('search_your')"
											<IMG SRC="{T_THEME_PATH}/images/buttons/yp1.png"
											NAME="search_your"
											ALT="{L_SEARCH_SELF}" BORDER=0
											HEIGHT=36 WIDTH=150
											</A>
											setrollover("{T_THEME_PATH}/images/buttons/yp2.png");
											</SCRIPT>
				<td><img src="{T_THEME_PATH}/images/p_menu/p_09.png" width="61" height="45" alt=""></td>
			<table id="bx" height="40" border="0" cellpadding="0" cellspacing="0">
				<td><img src="{T_THEME_PATH}/images/p_menu/p_10.png" width="61" height="40" alt=""></td>
				<td background="{T_THEME_PATH}/images/p_menu/p_11.png" width="50%" height="40"></td>
				<td background="{T_THEME_PATH}/images/p_menu/clock.png" width="350" height="40">
					<p class="gensmallclock" align="center">
						<script language="javascript" src="{T_TEMPLATE_PATH}/liveclock.js">
						</script>
					</p>
				<td background="{T_THEME_PATH}/images/p_menu/p_11.png" width="20%" height="40"></td>
				<td background="{T_THEME_PATH}/images/p_menu/p_11.png" width="30%" height="40" align="right">
						<a href="{U_DELETE_COOKIES}">{L_DELETE_COOKIES}</a>
				<td><img src="{T_THEME_PATH}/images/p_menu/p_13.png" width="61" height="40" alt=""></td>
[/i]
Ice
Re: navigation bar problems
Post by Ice »
You missed the edit to breadcrumbs.html
Stricken
Post by Stricken »
I dont understand Ice, I didn't see no editting to breadcrumbs.html in the install file, I'm doing this for hyper boy and here's the Breadcrumb.html please explain how it should look please or just show me if you dont mind?
	<table width="100%" cellspacing="0" cellpadding="0" style="margin-top: 5px;">
            <td><img src="{T_THEME_PATH}/images/nav01.png" width="46" height="55" alt=""></td>
		<td width="100%" background="{T_THEME_PATH}/images/nav02.png" width="100%" height="55">
			<p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> &#187; <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>
			<p class="datetime">{S_TIMEZONE}</p>
 <td><img src="{T_THEME_PATH}/images/nav03.png" width="46" height="55" alt=""></td>
hyperboy
Post by hyperboy »
yea i dont understand either can u tell/show us what to do because we cant figure this out
Open xml/subsilver2.xml, included in the package, with your browser. Then you'll find out what to do.
hyperboy
Post by hyperboy »
yea and i did all that and it still dont work idk what im doing wrong
Stricken
Post by Stricken »
Hm.. Ok I'll post the following information then someone might be able to help us.
Here is information on subsilver2
breadcrumbs:
	<table class="tablebg" width="100%" cellspacing="1" cellpadding="0" style="margin-top: 5px;">
		<td class="row1">
			<p class="breadcrumbs"><a href="{U_PORTAL}">{L_PORTAL}</a> &#187;<a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> &#187; <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>
overall_header:
<head>
{META}
// <![CDATA[
	if ({S_NEW_PM})
	if (!name)
		name = '_popup';
	return false;
function jumpto()
* Find a member
	return false;
	if (!parent)
	if (!parent)
		return;
<!-- IF ._file -->
		if (rectangle)
			var width = 200;
			var height = 0;
		obj.width = width;
		obj.Play();
</script>
</head>
<a name="top"></a>
	<div id="logodesc">
<!-- IF nFot $S_IN_PORTAL or not S_DISPLAY_MAINMENU -->
	<div id="menubar">
			<td class="genmed">
				<!-- IF not S_IS_BOT --><a href="{U_LOGIN_LOGOUT}"><img src="{T_THEME_PATH}/images/icon_mini_login.gif" width="12" height="13" alt="*" /> {L_LOGIN_LOGOUT}</a>&nbsp;<!-- ENDIF -->
				<!-- IF U_RESTORE_PERMISSIONS --> &nbsp;<a href="{U_RESTORE_PERMISSIONS}"><img src="{T_THEME_PATH}/images/icon_mini_login.gif" width="12" height="13" alt="*" /> {L_RESTORE_PERMISSIONS}</a><!-- ENDIF -->
						<!-- IF S_DISPLAY_PM --> &nbsp;<a href="{U_PRIVATEMSGS}"><img src="{T_THEME_PATH}/images/icon_mini_message.gif" width="12" height="13" alt="*" /> {PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a><!-- ENDIF -->
					<!-- ELSEIF S_REGISTER_ENABLED --> &nbsp;<a href="{U_REGISTER}"><img src="{T_THEME_PATH}/images/icon_mini_register.gif" width="12" height="13" alt="*" /> {L_REGISTER}</a>
			<td class="genmed" align="{S_CONTENT_FLOW_END}">
				<a href="{U_FAQ}"><img src="{T_THEME_PATH}/images/icon_mini_faq.gif" width="12" height="13" alt="*" /> {L_FAQ}</a>
				<!-- IF S_DISPLAY_SEARCH -->&nbsp; &nbsp;<a href="{U_SEARCH}"><img src="{T_THEME_PATH}/images/icon_mini_search.gif" width="12" height="13" alt="*" /> {L_SEARCH}</a><!-- ENDIF -->
					<!-- IF S_DISPLAY_MEMBERLIST -->&nbsp; &nbsp;<a href="{U_MEMBERLIST}"><img src="{T_THEME_PATH}/images/icon_mini_members.gif" width="12" height="13" alt="*" /> {L_MEMBERLIST}</a><!-- ENDIF -->
					<!-- IF S_USER_LOGGED_IN -->&nbsp; &nbsp;<a href="{U_PROFILE}"><img src="{T_THEME_PATH}/images/icon_mini_profile.gif" width="12" height="13" alt="*" /> {L_PROFILE}</a><!-- ENDIF -->
	<div id="datebar">
	<p class="searchbar">
	</p>
	<br style="clear: both;" />
That was for subsilver2 template, Found in this directory. </public_html/forum/styles/subsilver2/template>
Now here is the information for X-Treme template.
breadcrumbs:
overall-header:
<head>
{META}
// <![CDATA[
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
* Find a member
return false;
if (!parent)
if (!parent)
return;
<!-- IF ._file -->
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.Play();
</script>
</SCRIPT>
</head>
<a name="top"></a>
					<div id="logodesc">
					<A HREF="{U_INDEX}"
					NAME="home"
					HEIGHT=40 WIDTH=101
					</A>
					</SCRIPT>
					<A HREF="{U_FAQ}"
					NAME="faq"
					HEIGHT=40 WIDTH=101
					</A>
					</SCRIPT>
						<A HREF="{U_TEAM}"
						NAME="team"
						HEIGHT=40 WIDTH=101
						</A>
						</SCRIPT>
						NAME="search"
						HEIGHT=40 WIDTH=101
						</A>
						</SCRIPT>
							NAME="members"
							HEIGHT=40 WIDTH=101
							</A>
							</SCRIPT>
					<h5>
									<!-- ENDIF --></a>
					</h5>
					<h5>
					</h5>
							<h5>
							</h5>
									HEIGHT=36 WIDTH=150
									</A>
									</SCRIPT>
									HEIGHT=36 WIDTH=150
									</A>
									</SCRIPT>
											NAME="search_new"
											HEIGHT=36 WIDTH=150
											</A>
											</SCRIPT>
											NAME="search_your"
											HEIGHT=36 WIDTH=150
											</A>
											</SCRIPT>
						</script>
					</p>
That was for X-Treme Red template, Found in this directory. <public_html/forum/styles/X-Treme Red/template>
Remember, Were just trying to get on the nav bar for it to show up as (Portal -> Board Index) or whatever instead of just (Board Index)
All help is appreciated, thanks for helping guys, I know its a pain to review but i cannot find a mistake, I have double checked everything and still can't find out what is the problem.
That is correct: <a href="{U_PORTAL}">{L_PORTAL}</a> &#187;<a href="{U_INDEX}">{L_INDEX}</a>
Have you cleared your board cache?
