language bug
Current Version: 2.0.2
Released: 2013-10-27
elpanatibu
language bug
Post by elpanatibu »
Your Portal Version: 2.0.1
Boardlink: http://paencima.com.ve
nothing
nothing
i have my site config in spanish. portal works fine, but when users logoff, some blocks of portal change to english language, like recent topics, last news, who is online, Global announcements. the only way i found to fix this, was translate english file to spanish. any suggestion?
Re: language bug
Here is the Spanish translation: [Spanish[ES]] Translation for Board3 Portal 2.0.0
elpanatibu
Re: language bug
Kirk wrote:Here is the Spanish translation: [Spanish[ES]] Translation for Board3 Portal 2.0.0
i have the spanish translation...
Re: language bug
Then it contacts the author on http://www.phpbb-es.com/
elpanatibu
Re: language bug
Kirk wrote:Then it contacts the author on http://www.phpbb-es.com/
the translation works fine, but only when users are connected. when disconnect, the portal change some block to english..
same viewtopic.php?f=10&t=5466
Re: language bug
Have a set for guests other language?
Copy the Spanish language files in the folder root/language/en/mods/portal
elpanatibu
Re: language bug
Kirk wrote:Have a set for guests other language?
Copy the Spanish language files in the folder root/language/en/mods/portal was my solution. but how or where can i set the Spanish language for guests? the default language is spanish..
Re: language bug
On ACP/Board Settings Default language:
