Recent Posts
Current Version: 2.0.2
Released: 2013-10-27
bmroyer
Recent Posts
Post by bmroyer »
Your Portal Version: 2.0.1
Boardlink: http://battlecows.net
PHP Version: 12
f
f
I want to show my recent posts instead of recent topics. Also, I want teh members name below the listed recent post.If you look at my board you will see I modified it so the recent topics are listed on the right side. But I want recent posts, not topics. Here is the html as is.
<!-- IF .latest_announcements or .latest_hot_topics or .latest_topics -->
      <!-- IF .latest_topics --><td class="row1"><strong>{L_PORTAL_RECENT_TOPIC}</strong></td><!-- ENDIF -->
      <td class="row1" width="100%" valign="top">
         <!-- BEGIN latest_topics -->
            <a href="{latest_topics.U_VIEW_TOPIC}" title="{latest_topics.FULL_TITLE}">{latest_topics.TITLE}</a><br />
         <!-- END latest_topics -->
{$C_BLOCK_F_L}{$C_BLOCK_F_R}
[/i]
bmroyer
Re: Recent Posts
Post by bmroyer »
bump. Come on it should be that hard to change the "recent topics" to "recent posts." And I wouldn't mind having the last posters name underneath the title in the sidebar.
bmroyer
Re: Recent Posts
Post by bmroyer »
I want my latest posts to look like this http://web.archive.org/web/200304071600 ... php?page=1
bmroyer
Re: Recent Posts
Post by bmroyer »
Lack of support eh?
Re: Recent Posts
bmroyer wrote:Lack of support eh?
Not saying something.
In ACP click on the green cogs in Lastest News
Choose from Compact news block style: yes
Choose display at the number of replies and views: yes
This is a phpBB 2.0.4 where you have linked
bmroyer
Re: Recent Posts
Post by bmroyer »
I know that is php 2. I just want my latest posts to look the same as the one I linked. Right now it is showing my latest "topics." I want it to show my latest "posts" and have the name of the last poster below it like the one I linked.
Re: Recent Posts
Open: root/portal/modules/portal_news.php
Find:
public $columns = 21;
Replace with:
public $columns = 31;
Find:
			return 'news_center.html';
Add after:
		global $config, $template, $db, $user, $auth, $cache, $phpEx, $phpbb_root_path;
		$news = request_var('news', -1);
		$news = ($news > $config['board3_news_length_' . $module_id] -1) ? -1 : $news;
		$user->add_lang('viewforum');
		$start = request_var('np', 0);
		$start = ($start < 0) ? 0 : $start;
		// Fetch news from portal/includes/functions.php with check if "read full" is requested.
		$portal_news_length = ($news < 0) ? $config['board3_news_length_' . $module_id] : 0;
		$fetch_news = phpbb_fetch_posts($module_id, $config['board3_news_forum_' . $module_id], $config['board3_news_permissions_' . $module_id], $config['board3_number_of_news_' . $module_id], $portal_news_length, 0, ($config['board3_show_all_news_' . $module_id]) ? 'news_all' : 'news', $start, $config['board3_news_exclude_' . $module_id]);
		// Any news present? If not terminate it here.
		if (sizeof($fetch_news) == 0)
			$template->assign_block_vars('news_row', array(
				'S_NO_TOPICS'	=> true,
				'S_NOT_LAST'	=> false,
			// Count number of posts for news archive, considering if permission check is dis- or enabled.
			if ($config['board3_news_archive_' . $module_id])
				$permissions = $config['board3_news_permissions_' . $module_id];
				$forum_from = $config['board3_news_forum_' . $module_id];
				$forum_from = (strpos($forum_from, ',') !== false) ? explode(',', $forum_from) : (($forum_from != '') ? array($forum_from) : array());
				$str_where = '';
				if($permissions == true)
					$disallow_access = array_unique(array_keys($auth->acl_getf('!f_read', true)));
					$disallow_access = array();
				if($config['board3_news_exclude_' . $module_id] == true)
					$disallow_access = array_merge($disallow_access, $forum_from);
					$forum_from = array();
				if(sizeof($forum_from))
					$disallow_access = array_diff($forum_from, $disallow_access);
					if(!sizeof($disallow_access))
						return array();
					foreach($disallow_access as $acc_id)
						$acc_id = (int) $acc_id;
						$str_where .= "forum_id = $acc_id OR ";
						$str_where .= "forum_id <> $acc_id AND ";
				$str_where = (strlen($str_where) > 0) ? 'AND (' . trim(substr($str_where, 0, -4)) . ')' : '';
				$topic_type = ($config['board3_show_all_news_' . $module_id]) ? '(topic_type <> ' . POST_ANNOUNCE . ') AND (topic_type <> ' . POST_GLOBAL . ')' : 'topic_type = ' . POST_NORMAL;
				$sql = 'SELECT COUNT(topic_id) AS num_topics
					FROM ' . TOPICS_TABLE . '
					WHERE ' . $topic_type . '
						AND topic_approved = 1
						AND topic_moved_id = 0
						' . $str_where;
					$total_news = (int) $db->sql_fetchfield('num_topics');
					$db->sql_freeresult($result);
			$topic_tracking_info = get_portal_tracking_info($fetch_news);
			if($news < 0)
			// Show the news overview
				$count = $fetch_news['topic_count'];
				for ($i = 0; $i < $count; $i++)
					if(isset($fetch_news[$i]['striped']) && $fetch_news[$i]['striped'] == true)
						$open_bracket = '[ ';
						$close_bracket = ' ]';
						$read_full = $user->lang['READ_FULL'];
						$open_bracket = '';
						$close_bracket = '';
						$read_full = '';
					// unread?
					$forum_id = $fetch_news[$i]['forum_id'];
					$topic_id = $fetch_news[$i]['topic_id'];
					$unread_topic = (isset($topic_tracking_info[$topic_id]) && $fetch_news[$i]['topic_last_post_time'] > $topic_tracking_info[$topic_id]) ? true : false;
					$read_full_url = (isset($_GET['np'])) ? 'np='. $start . '&news=' . $i . '#n' . $i : 'news=' . $i . '#n' . $i;
					$view_topic_url = append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . (($fetch_news[$i]['forum_id']) ? $fetch_news[$i]['forum_id'] : $forum_id) . '&t=' . $topic_id);
						$pagination = generate_portal_pagination(append_sid("{$phpbb_root_path}portal.$phpEx"), $total_news, $config['board3_number_of_news_' . $module_id], $start, ($config['board3_show_all_news_' . $module_id]) ? 'news_all' : 'news');
					$replies = ($auth->acl_get('m_approve', $forum_id)) ? $fetch_news[$i]['topic_replies_real'] : $fetch_news[$i]['topic_replies'];
					$folder_img = $folder_alt = $topic_type = $folder = $folder_new = '';
					switch ($fetch_news[$i]['topic_type'])
						case POST_STICKY:
							$folder = 'sticky_read';
							$folder_new = 'sticky_unread';
						break;
						case POST_ANNOUNCE:
							$folder = 'announce_read';
							$folder_new = 'announce_unread';
						break;
						default:
							$folder = 'topic_read';
							$folder_new = 'topic_unread';
							if ($config['hot_threshold'] && $replies >= $config['hot_threshold'] && $fetch_news[$i]['topic_status'] != ITEM_LOCKED)
								$folder .= '_hot';
								$folder_new .= '_hot';
						break;
					if ($fetch_news[$i]['topic_status'] == ITEM_LOCKED)
						$folder .= '_locked';
						$folder_new .= '_locked';
					if ($fetch_news[$i]['topic_posted'])
						$folder .= '_mine';
						$folder_new .= '_mine';
					$folder_img = ($unread_topic) ? $folder_new : $folder;
					$folder_alt = ($unread_topic) ? 'NEW_POSTS' : (($fetch_news[$i]['topic_status'] == ITEM_LOCKED) ? 'TOPIC_LOCKED' : 'NO_NEW_POSTS');
					// Grab icons
					$icons = $cache->obtain_icons();
						'ATTACH_ICON_IMG'		=> ($fetch_news[$i]['attachment'] && $config['allow_attachments']) ? $user->img('icon_topic_attach', $user->lang['TOTAL_ATTACHMENTS']) : '',
						'FORUM_NAME'			=> ($forum_id) ? $fetch_news[$i]['forum_name'] : '',
						'TITLE'					=> $fetch_news[$i]['topic_title'],
						'POSTER'				=> $fetch_news[$i]['username'],
						'POSTER_FULL'			=> $fetch_news[$i]['username_full'],
						'USERNAME_FULL_LAST'	=> $fetch_news[$i]['username_full_last'],
						'U_USER_PROFILE'		=> (($fetch_news[$i]['user_type'] == USER_NORMAL || $fetch_news[$i]['user_type'] == USER_FOUNDER) && $fetch_news[$i]['user_id'] != ANONYMOUS) ? append_sid("{$phpbb_root_path}memberlist.$phpEx", 'mode=viewprofile&u=' . $fetch_news[$i]['user_id']) : '',
						'TIME'					=> $fetch_news[$i]['topic_time'],
						'LAST_POST_TIME'		=> $user->format_date($fetch_news[$i]['topic_last_post_time']),
						'TEXT'					=> $fetch_news[$i]['post_text'],
						'REPLIES'				=> $fetch_news[$i]['topic_replies'],
						'TOPIC_VIEWS'			=> $fetch_news[$i]['topic_views'],
						'N_ID'					=> $i,
						'TOPIC_FOLDER_IMG'		=> $user->img($folder_img, $folder_alt),
						'TOPIC_FOLDER_IMG_SRC'  => $user->img($folder_img, $folder_alt, false, '', 'src'),
						'TOPIC_FOLDER_IMG_ALT'  => $user->lang[$folder_alt],
						'TOPIC_ICON_IMG'		=> (!empty($icons[$fetch_news[$i]['icon_id']])) ? $icons[$fetch_news[$i]['icon_id']]['img'] : '',
						'TOPIC_ICON_IMG_WIDTH'	=> (!empty($icons[$fetch_news[$i]['icon_id']])) ? $icons[$fetch_news[$i]['icon_id']]['width'] : '',
						'TOPIC_ICON_IMG_HEIGHT'	=> (!empty($icons[$fetch_news[$i]['icon_id']])) ? $icons[$fetch_news[$i]['icon_id']]['height'] : '',
						'FOLDER_IMG'			=> $user->img('topic_read', 'NO_NEW_POSTS'),
						'U_VIEWFORUM'			=> append_sid("{$phpbb_root_path}viewforum.$phpEx", 'f=' . $fetch_news[$i]['forum_id']),
						'U_LAST_COMMENTS'		=> append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $fetch_news[$i]['forum_id'] . '&t=' . $fetch_news[$i]['topic_id'] . '&p=' . $fetch_news[$i]['topic_last_post_id'] . '#p' . $fetch_news[$i]['topic_last_post_id']),
						'U_VIEW_COMMENTS'		=> append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $fetch_news[$i]['forum_id'] . '&t=' . $fetch_news[$i]['topic_id']),
						'U_VIEW_UNREAD'			=> append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $fetch_news[$i]['forum_id'] . '&t=' . $fetch_news[$i]['topic_id'] . '&view=unread#unread'),
						'U_POST_COMMENT'		=> append_sid("{$phpbb_root_path}posting.$phpEx", 'mode=reply&f=' . $fetch_news[$i]['forum_id'] . '&t=' . $fetch_news[$i]['topic_id']),
						'U_READ_FULL'			=> append_sid("{$phpbb_root_path}portal.$phpEx", $read_full_url),
						'L_READ_FULL'			=> $read_full,
						'OPEN'					=> $open_bracket,
						'CLOSE'					=> $close_bracket,
						'S_NOT_LAST'			=> ($i < sizeof($fetch_news) - 1) ? true : false,
						'S_POLL'				=> $fetch_news[$i]['poll'],
						'S_UNREAD_INFO'			=> $unread_topic,
						'PAGINATION'			=> topic_generate_pagination($fetch_news[$i]['topic_replies'], $view_topic_url),
						'S_HAS_ATTACHMENTS'		=> (!empty($fetch_news[$i]['attachments'])) ? true : false,
					if(!empty($fetch_news[$i]['attachments']))
						foreach ($fetch_news[$i]['attachments'] as $attachment)
							$template->assign_block_vars('news_row.attachment', array(
								'DISPLAY_ATTACHMENT'	=> $attachment)
					if ($config['board3_number_of_news_' . $module_id] <> 0 && $config['board3_news_archive_' . $module_id])
						$template->assign_vars(array(
							'NP_PAGINATION'		=> $pagination,
							'TOTAL_NEWS'		=> ($total_news == 1) ? $user->lang['VIEW_FORUM_TOPIC'] : sprintf($user->lang['VIEW_FORUM_TOPICS'], $total_news),
							'NP_PAGE_NUMBER'	=> on_page($total_news, $config['board3_number_of_news_' . $module_id], $start))
			// Show "read full" page
				$i = $news;
				$read_full = $user->lang['BACK'];
				$read_full_url = (isset($_GET['np'])) ? append_sid("{$phpbb_root_path}portal.$phpEx", "np=$start#n$i") : append_sid("{$phpbb_root_path}portal.$phpEx#n$i");
					'N_ID'				=> $i,
					'U_LAST_COMMENTS'	=> append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'p=' . $fetch_news[$i]['topic_last_post_id'] . '#p' . $fetch_news[$i]['topic_last_post_id']),
					'U_READ_FULL'		=> $read_full_url,
		$topic_icons = false;
		if(!empty($fetch_news['topic_icons']))
			$topic_icons = true;
			'NEWEST_POST_IMG'			=> $user->img('icon_topic_newest', 'VIEW_NEWEST_POST'),
			'READ_POST_IMG'				=> $user->img('icon_topic_latest', 'VIEW_LATEST_POST'),
			'GOTO_PAGE_IMG'				=> $user->img('icon_post_target', 'GOTO_PAGE'),
			'S_NEWEST_OR_FIRST'			=> ($config['board3_news_show_last_' . $module_id]) ? $user->lang['JUMP_NEWEST'] : $user->lang['JUMP_FIRST'],
			'POSTED_BY_TEXT'			=> ($config['board3_news_show_last_' . $module_id]) ? $user->lang['LAST_POST'] : $user->lang['POSTED'],
			'S_DISPLAY_NEWS_RVS'		=> ($config['board3_show_news_replies_views_' . $module_id]) ? true : false,
			'S_TOPIC_ICONS'				=> $topic_icons,
		if($config['board3_news_style_' . $module_id])
			return 'news_compact_side.html';
			return 'news_side.html';
Open: root/language/en/mods/portal/portal_news_module.php
Find:
'LATEST_NEWS'			=> 'Latest news',
Add after:
'LATEST_POSTS'			=> 'Latest Posts',
As you save this file to the correct coding
UTF-8 without BOM
For prosilver based styles
Create a new file with the following content:
<!-- BEGIN news_row -->
<!-- IF news_row.S_NO_TOPICS -->
{$LR_BLOCK_H_L}<!-- IF $S_BLOCK_ICON --><img src="{$IMAGE_SRC}" width="{$IMAGE_WIDTH}" height="{$IMAGE_HEIGHT}" alt="" />&nbsp;<!-- ENDIF -->{L_LATEST_POSTS}{$LR_BLOCK_H_R}
	<div class="post bg2" style="margin-bottom: 0px">
			<span style="text-align: center;"><strong>{L_NO_NEWS}</strong></span>
<!-- ELSE  -->
<!-- IF news_row.S_FIRST_ROW  -->
	<div style="height: 350px; overflow: auto;">
<ul class="topiclist topics">
	<li class="row<!-- IF news_row.S_ROW_COUNT is even --> bg1<!-- ELSE --> bg2<!-- ENDIF -->">
		<dl>
			<dt style="<!-- IF S_DISPLAY_NEWS_RVS -->width: 44%;<!-- ELSE -->width: 97%;<!-- ENDIF --> " title="{news_row.TOPIC_FOLDER_IMG_ALT}"><!-- IF news_row.S_POLL --><strong>{L_VIEW_TOPIC_POLL}</strong><!-- ENDIF --><a href="{news_row.U_VIEW_COMMENTS}" title="{news_row.TITLE}" class="topictitle">{news_row.TITLE}</a>
					<br /> {L_POST_BY_AUTHOR} {news_row.USERNAME_FULL_LAST} <br /> {news_row.TIME}
		</dl>
	</li>
<!-- IF news_row.S_LAST_ROW -->
<!-- END news_row -->
This memory file named news_compact_side.html and upload it to the following directory.
root/styles/yourstyles/template/portal/modules/
For subsilver2 based styles
<div id="pagecontent">
	<tr class="row1">
		<td align="center">
			<span class="gensmall"><strong>{L_NO_NEWS}</strong></span>
				<td class="row1">
					<!-- IF news_row.S_POLL --> <strong style="font-size:1.1em;">{L_VIEW_TOPIC_POLL} </strong><!-- ENDIF --><a title="{news_row.TITLE}" href="{news_row.U_VIEW_COMMENTS}" class="topictitle">{news_row.TITLE}</a>
					<p class="gensmall">{L_POST_BY_AUTHOR} {news_row.USERNAME_FULL_LAST} <br /> {news_row.TIME}
					</p>
Knowledge Base: Changes to forums styles
In ACP click on the green cogs in Latest News
Choose display at the number of replies and views: no
bmroyer
Re: Recent Posts
Post by bmroyer »
That changes my latest news, I'm talking about the recent posts in the right hand corner.
Re: Recent Posts
Then you have to create a module to yourself.
How to edit a module file
How to create a module zip for Board3 Portal
bmroyer
Re: Recent Posts
Post by bmroyer »
There is already a module called "recent topics." Why should I create a new one when there is already one for what I need? It just needs sprucing up.
Re: Recent Posts
The recent topics block linked to the first post of a topic, not to last post how you want to have it.
It would have to be changed portal_recent.php.
Try this module.
bmroyer
Re: Recent Posts
Post by bmroyer »
That link I showed you earlier with the php2 board is using a portal called "nutport." I want to copy how he has the most recent posts in the right hand corner. Everytime someone posts something, it goes to the top of the "recent" tab. I don't want the most recent topics, I want the most recent posts. People post more replies than they do new topics. I want to see the activity on the board without clicking the "recent posts" link. I also want to show the name of the last poster, along with the date/time like they have it on nutport.
