Problem with Install
Current Version: 2.0.2
Released: 2013-10-27
Kaos
Post by Kaos »
Boardlink: http://deathwish4x4.ca
Vanilla Install, setup my forums.
Tried changing line 126 and a few other edits to the file.
Hello all,
I have a new install of phpBB3. Installed portal today. After install I get
Parse error: syntax error, unexpected '}' in /home/death/public_html/cache/tpl_prosilver_overall_header.html.php on line 126
Now this is part (Line 110 to 156) of my actual file from /styles/prosilver/template/overall_header.html;
			<div id="search-box">
				<form action="{U_SEARCH}" method="get" id="search">
				<fieldset>
				</fieldset>
				</form>
				<li class="rightside"><a href="#" onclick="fontsizeup(); return false;" onkeypress="return fontsizeup(event);" class="fontsize" title="{L_CHANGE_FONT_SIZE}">{L_CHANGE_FONT_SIZE}</a></li>
				<li class="icon-ucp">
					<a href="{U_PROFILE}" title="{L_PROFILE}" accesskey="e">{L_PROFILE}</a>
						<!-- IF S_DISPLAY_PM --> (<a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a>)<!-- ENDIF -->
					<!-- IF S_DISPLAY_SEARCH --> &bull;
				</li>
Please help?
Thanks![/i]
Re: Problem with Install
You have a <- ENDIF -> too much
Find:
                <fieldset>
                </fieldset>
                </form>
Replace with:
                <fieldset>
                </fieldset>
                </form>
Kaos
Post by Kaos »
Okay, I'm going to reinstall the portal this evening.
Thanks!
Kaos wrote:Okay, I'm going to reinstall the portal this evening.
You do not need to make, change what I have written.
Kaos
Post by Kaos »
Hi Kirk,
I had uninstalled it so my board would be operational.
I reinstalled, had the same error, implemented your fix- all is well.
Thanks for the help!
