Boardlink: http://mykgm.net
I installed new theme called macinscott_3. After my first installed, theres is some error says file could not found. It was for portal.php, the theme is look fine at index.php
So i copy the "portal" folder frm /public_html/portal/styles/subsilver2/template/ to /public_html/portal/styles/Macinscott_3/template/ and it work.
However... no graphic appear.
Theme (style) not working very well
sagaraptor
Re: Theme (style) not working very well
Open the board3 zip file, copy all folders from root/style/subsilver2 to /public_html/portal/styles/Macinscott_3
