Change Who is Online block
UnknownReverence
Post by UnknownReverence »
Edit: I figured it out, but it won't show the statistics if I have the side statistics turned off.
Your Portal Version: 2.0.1
Boardlink: http://paragongaming.x10.mx/
Not really a problem, but a change I would like to make.
Nothing.
I'd like to change the who is online block from this (original):
To this (what it looks like on the board):
(Before logging in)
(After logging in)
Re: Change Who is Online block
This has nothing to do with the portal, so please contact the styleauthor or phpBB.com
UnknownReverence
I don't need to edit the way it looks anymore. I'm trying to figure out how to show the statistics. They aren't showing on the who is online module when I have the statistics module turned off.
Edit: Never mind. I don't need it anymore. Thanks for the reply though.
