Portal issues
Current Version: 2.0.2
Released: 2013-10-27
UnknownReverence
Portal issues
Post by UnknownReverence »
Your Portal Version: 2.0.1
Boardlink: http://paragon-gaming.zxq.net/portal.php
I installed everything correctly and have done them over again to double check.
Double checking the edits.
I installed the portal on my page, but there's a few problems. The bullets are off of where they're supposed to be, and the welcome message overlaps the background. Also, the portal link at the top is missing. It also seems the whole background of everything disappeared now and it's just all white background since I messed with the blocks.
I followed the directions and also did the directions located at this link. (viewtopic.php?f=57&t=5323)
UnknownReverence
Re: Portal issues
It seems as though I've fixed the background and bullets, but now the welcome and custom blocks are aligned to the right and I still don't have the portal link on my board.
Re: Portal issues
The error is in overall_header.html
your code:
    <!-- INCLUDE navbar.html -->
Change it so
UnknownReverence
Re: Portal issues
I've tried both ways. The whole navbar disappeared when I did it that way.
Re: Portal issues
You must in ACP at Display the phpBB Header on the portal put on yes
UnknownReverence
Re: Portal issues
It shows the navbar again, but still no portal link.
Re: Portal issues
UnknownReverence wrote:It shows the navbar again, but still no portal link.
Did you do: Knowledge Base: Changes to forums styles
UnknownReverence
Re: Portal issues
Yes. I did all of that after I changed the overall_header.html
Re: Portal issues
Go to the folder via FTP cache and delete everything except for
. htaccess and index.htm
Refresh your Browser
UnknownReverence
Re: Portal issues
Still nothing. I'm sorry your attempts to help aren't working. I do appreciate it though.
Re: Portal issues
For me, the style works: Demo
I have this style, including all changes for the portal provided to download.
http://reyno41.bplaced.net/phpBB3/downl ... lution.zip
UnknownReverence
Re: Portal issues
Kirk wrote:For me, the style works: Demo
Thank you. That fixed everything except the link for the navbar. That's all I need to fix now.
Re: Portal issues
Does the portal with prosilver without problems?
UnknownReverence
Re: Portal issues
Kirk wrote:Does the portal with prosilver without problems?
I actually haven't tried it with another style. I also didn't do the viewonline, constants, functions, session, and htaccess edits in the original install directions either. Wasn't sure if I needed to or not. Just followed the directions from that link I gave. Not sure if that has something to do with it or not.
Re: Portal issues
You have to make the instructions as it is in the install.xml.
