Your Portal Version: 2.0.0
MySQL Version: How to change properties of Blocks?
Nothing
I want to reconfigure the blocks of portal. I want help of following points:
1. How to change the background color of the block?
2. How to change the text color and properties of the block?
3. How to show a block in whole forum? I want to show the top block always.
4. How to set an image as the background of the particular block?
5. How to hide titles of block?
Help will be appreciated. Thanks in Advance.
scorpio
- phpBB.de User: Scorpio
- phpBB.com User: scorpiors
- phpBB.de User: Kirk
Re: How to change properties of Blocks?
Look here: https://www.phpbb.de/community/viewtopi ... 2#p1306572 it's in Germanscorpio wrote:1. How to change the background color of the block?
This is currently not possible.scorpio wrote:3. How to show a block in whole forum? I want to show the top block always.
Open the colour.ccs your Stylesscorpio wrote:4. How to set an image as the background of the particular block?
Find:
.bg3 { background-color: #cadceb; }Code: Select all
.bg1-portal {
background-color: #ECF3F7;
background-image: url("{T_THEME_PATH}/images/bg_forum.gif");
.bg2-portal {
Replace with: .bg1-portal .bg2-portal
Reason: corrected code
scorpio
Sir, thanks for quick response.
