igsepia (Base: prosilver)
Style: igsepia (This style only works with "prosilver"! / Dieser Styles funktioniert nur mit "prosilver"!)
Style Version: 1.0.2
Style Download: http://www.ongray-design.de/forum/viewt ... f=63&t=293
to: root/styles/igsepia/template/portal/*.*
to: root/styles/igsepia/theme/portal.css
to: root/styles/igsepia/theme/images/portal/*.*
open: root/styles/igsepia/template/overall_header.html
<div id="page-header">
Add these lines on a new blank line after the preceding line(s) to find.
open: root/styles/igsepia/template/template/overall_footer.html
open: root/styles/igsepia/theme/stylesheet.css
nach: root/styles/igsepia/template/portal/*.*
nach: root/styles/igsepia/theme/portal.css
nach: root/styles/igsepia/theme/images/portal/*.*
Öffne: root/styles/igsepia/template/overall_header.html
<a href="{U_INDEX}" title="{L_INDEX}">{L_INDEX}</a>
Öffne: root/styles/igsepia/template/overall_footer.html
Öffne: root/styles/igsepia/theme/stylesheet.css
