Boardlink: http://brasilcheat.uni.cc/forum/portal.php
Hello staff of the Board3 support.
I installed the portal, and there is a small problem in the block of MENU.
When I ask him, the forum is left with distorted and different templates.
In my board3 portal lack only the block of MENU, I would count much with the help of you.
http://www.brasilcheat.uni.cc/forum/portal.php
I also know that it is possible to create a custom block as the portal here the same support.
Recalling that if I get the block of navigation, the portal is perfeito.Normal!
Thanks to all.
Menu BLOCK problem
