WoWMistsofPandaria (Base: prosilver)
Style: WoWMistsofPandaria (This style only works with "prosilver"! / Dieser Styles funktioniert nur mit "prosilver"!)
Style Version: 3.0.11
Style Download: http://demo.phpbb3styles.net/WoWMistsofPandaria
to: root/styles/WoWMistsofPandaria/template/portal/*.*
copy: root/styles/prosilver/theme/portal.css/*.*
to: root/styles/WoWMistsofPandaria/theme/*.*
to: root/styles/WoWMistsofPandaria/theme/images/portal/*.*
open: root/styles/WoWMistsofPandaria/template/overall_header.html.html
<div id="menus">
<ul id="topnav">
<!-- IF U_PORTAL --><li><a href="{U_PORTAL}" accesskey="h">{L_PORTAL}</a></li><!-- ENDIF -->
<!-- IF S_DISPLAY_SEARCH --><li><a href="{U_SEARCH}">{L_SEARCH}</a></li><!-- ENDIF -->
open: root/styles/WoWMistsofPandaria/template/overall_footer.html
open: root/styles/WoWMistsofPandaria/theme/stylesheet.css
nach: root/styles/WoWMistsofPandaria/template/portal/*.*
kopiere: root/styles/prosilver/theme/portal.css/*.*
nach: root/styles/WoWMistsofPandaria/theme/*.*
nach: root/styles/WoWMistsofPandaria/theme/images/portal/*.*
Öffne: root/styles/WoWMistsofPandaria/template/overall_header.html
<div id="menus">
<ul id="topnav">
Öffne: root/styles/WoWMistsofPandaria/template/overall_footer.html
Öffne: root/styles/WoWMistsofPandaria/theme/stylesheet.css
