FireFox Loop registered group login
Current Version: 2.0.2
Released: 2013-10-27
tenoch
Post by tenoch »
Your Portal Version: 2.1.1
I was using this mod, latest version 2.0.1
And all was working fine
But some users reported that they were having infinit loop using firefox
I tested it with admin user and there was no problem, but with another user login (registeded group) I see that this problem is happenig
If I remove in .htaccess
the sentence portal.php after DirectoryIndex
There is not loop any more, but the mod board3 does not work either
How can I solve this?
Thanks
Re: FireFox Loop registered group login
Can you set me a test account, so I can see the problem?
tenoch
Post by tenoch »
user
pass
In google chrome all is ok
This error is only in firefox
I haven´t tested it in IE yet
tenoch wrote: http://www.construaprende.com/foros/
If I am logged in can not see the portal.
Check real-time user-rights for registered users. Please add the portal-code back into the .htaccess.
If still the problem is, they disable the blocks individually to see which block could be the problem.
I suspect the problem in the block "Anuncios globales - Noticias".
It may be you have the wrong smiley code in the post. Change it smilie code in the admin area. Compare Code with standard smiley code.
Turn on the debug mode to see error.
root/config.php:
disable:
//@define('DEBUG', true);
//@define('DEBUG_EXTRA', true);
enable:
tenoch
Post by tenoch »
root/config.php:
disable:
enable:
Thank you
The problem was in permissions
It was disabled to see portal, for registered
Regards
