Custom Subsilver Style portal install
Mordynak
Post by Mordynak »
Your Portal Version: 2.0.1
Hi all. Just trying to install Board 3 Portal on an old subsilver style I've updated. Just not sure what to do with the overall header file.
I have the portal installed on my site and working on prosilver fine. Just having troubles with this particular style.
I'm not able to find anything its telling too on the portals subsilver style installation guide so I just don't know where to put things.
This is the overall header.
<head>
<!-- IF S_ENABLE_FEEDS -->
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7; IE=EmulateIE9" />
{META}
   phpBB style name: DarkFantasy
   Based on style:   subsilver2
   Modified by:     Daniel St. Jules ( http://www.codfaction.com )
<!--[if IE]><link rel="stylesheet" href="{T_THEME_PATH}/ie.css" type="text/css" /><![endif]-->
<!--[if lte IE 6]>
<script defer type="text/javascript" src="{T_TEMPLATE_PATH}/pngfix.js"></script>
<link rel="stylesheet" href="{T_THEME_PATH}/ie6.css" type="text/css" />
<![endif]-->
// <![CDATA[
<!-- IF S_USER_PM_POPUP and S_NEW_PM -->
	if (!name)
		name = '_popup';
	return false;
function jumpto()
	var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
	return false;
* Mark/unmark checklist
	if (!parent)
	if (!parent)
		return;
			rb[r].checked = state;
<!-- IF ._file -->
	function play_qt_file(obj)
		if (rectangle)
			var width = 200;
			var height = 0;
		obj.width = width;
		obj.height = height + 16;
		obj.Play();
</script>
</head>
<a name="top"></a>
<div id="container">
<div id="wrapper">
<div id="header">
<a href="{U_INDEX}">{SITE_LOGO_IMG}</a>
<div id="top_menu">
	<!-- IF S_DISPLAY_SEARCH --><a id="search" href="{U_SEARCH}">{L_SEARCH}</a><!-- ENDIF -->
	<!-- IF not S_IS_BOT --><!-- IF S_DISPLAY_MEMBERLIST --><a id="members" href="{U_MEMBERLIST}">{L_MEMBERLIST}</a><!-- ENDIF -->
	<!-- IF S_USER_LOGGED_IN --><a id="ucp" href="{U_PROFILE}">{L_PROFILE}</a><!-- ENDIF --><!-- ENDIF -->
	<a id="faq" href="{U_FAQ}">{L_FAQ}</a>
<div id="content1">
<div id="content2">
<div id="content3">
	<br style="clear: both;" />
	<p class="genmed"><!-- IF not S_IS_BOT --><a href="{U_LOGIN_LOGOUT}"><b>{L_LOGIN_LOGOUT}</b></a><!-- ENDIF -->
	<!-- IF S_DISPLAY_PM --> | <a href="{U_PRIVATEMSGS}"><b>{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></b></a><!-- ENDIF -->
	<!-- ELSEIF S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) --> | <a href="{U_REGISTER}"><b>{L_REGISTER}</b></a>
	<!-- IF U_RESTORE_PERMISSIONS --><br /><a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a><!-- ENDIF -->
	<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --><br /><span style="color: red;">{L_BOARD_DISABLED}</span><!-- ENDIF --></p>
	<p class="searchbar">
		<!-- IF S_USER_LOGGED_IN or S_LOAD_UNREADS -->
		<span style="float: {S_CONTENT_FLOW_END};"><!-- IF S_LOAD_UNREADS --><a href="{U_SEARCH_UNREAD}">{L_SEARCH_UNREAD}</a><!-- IF S_USER_LOGGED_IN --> | <!-- ENDIF --><!-- ENDIF --><!-- IF S_USER_LOGGED_IN --><a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a> | <a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a><!-- ENDIF --></span>
	</p>
	<br style="clear: both;" /><br />
	<div id="wrapheader"></div>
All your help is greatly appreciated.
Thank you in advance.[/i]
Re: Custom Subsilver Style portal install
This style DarkFantasy is for the phpBB version: 3.0.7 and is unsuitable for the Portal version 2.0.1.
You have this style on the phpBB version: 3.0.11 update.
Mordynak
Post by Mordynak »
I've already updated the style to 3.0.11. You even locked and moved a post i made asking about it.
General questions about updating style have nothing to do with the portal.
For your overall_header.html try it once with this guide: viewtopic.php?f=47&t=3389
Maybe it hiflt you.
Mordynak
Post by Mordynak »
This topic isn't related to asking about updating a style. Only how to get Board3Portal to work on it.
Thank you for the link however. I will try it now.
EDIT: OK. Just made the changes listed on that page. They are pretty much exactly what i had tried in the past.
It has work to a certain degree. The portal shows up but the style seems to be a bit off.
The test colour isnt correct, the background image is missing. The column of the portal isn't displayed. (Currently only have the right one active) Also, it doesn't display the "Administration Control Panel" link at the bottom of the page.
Any ideas whats going on here? I imagine its just not using the correct stylesheet or something but i just don't know.
Really appreciate the help. Thank you!
EDIT 2: I also get this error message on the actual page itself.
Warning: Cannot modify header information - headers already sent by (output started at /var/sites/p/provincecyrodiil.project-tamriel.com/public_html/cache/tpl_DarkFantasy_overall_header.html.php:2) in /var/sites/p/provincecyrodiil.project-tamriel.com/public_html/includes/functions.php on line 2718
Thanks again.
This manual is for the Board3Portal Version: 1.0.4 / 1.0.5 this, there may be errors, an attempt was worth it.
Since there are not that style for phpBB 3.0.11, unfortunately I can not help sorry.
Try these instructions:
Style: DarkFantasy
Style Version: 1.0.16
phpBB Version: 3.0.8
Board3Portal Version: 2.0.0b1
Style Download: http://www.phpbb.com/customise/db/style/darkfantasy/
to: root/styles/DarkFantasy/template/portal/*.*
to: root/styles/DarkFantasy/theme/images/portal/*.*
open: root/styles/DarkFantasy/template/breadcrumbs.html
open: root/styles/DarkFantasy/template/overall_header.html
<div id="content3">
open: root/styles/DarkFantasy/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<table class="tablebg" cellspacing="1" width="100%"><tr><th style="padding-top: 3px; padding-bottom: 10px;"><span style="float: left;">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</span></th></tr></table>' -->
<!-- DEFINE $LR_BLOCK_F_R = '<br />' -->
<!-- DEFINE $C_BLOCK_H_L = '<table class="tablebg" cellspacing="1" cellpadding="0" width="100%"><tr><th><span style="text-align: center">' -->
<!-- DEFINE $C_BLOCK_H_R = '</span></th></tr></table>' -->
<!-- DEFINE $C_BLOCK_F_R = '<br />' -->
nach: root/styles/DarkFantasy/template/portal/*.*
nach: root/styles/DarkFantasy/theme/images/portal/*.*
Öffne: root/styles/DarkFantasy/template/breadcrumbs.html
Öffne: root/styles/DarkFantasy/template/overall_header.html
<div id="content3">
Öffne: root/styles/DarkFantasy/template/portal/_block_config.html
Mordynak
Post by Mordynak »
Thanks again guys.
Archivar. Do i need to install that exact style version you linked to?
I ask because I already downloaded this version of the style and updated it according to this page. Then I added the portal files included in your mod to the style. Other than that, and the changes Kirk kindly assisted me with, that's all I've changed.
Mordynak wrote: Archivar. Do i need to install that exact style version you linked to?
No!
I had the instructions written in 2011 but not published because of the styles to old version.
Mordynak
Post by Mordynak »
I've been unsuccessful in getting this working so far. This is the board now with the changes made.
I could make a test account so you can have a look at the style. Its an active board so im currently using the working modded prosilver style.
If theres anything you need to know in order to help let me know. I'm really not sure what to do.
Thanks guys
I do not understand what problem you have? :?
Mordynak
Post by Mordynak »
Well it looks like this
Image And there is no admin control panel link at the bottom.
The style works 100% on everything but the portal. Also, the standard subsilver style is working fine with the portal.
Thanks again.
I can not see the styles "DarkFantasy".
Mordynak
Post by Mordynak »
Ok, i just set it so that guests could change the style via the portal. And the style works fine for guests, but as soon as you login it breaks.
Give me admin access via PM.
And they turn on the debug mode.
Return to “Styles Support”
