Missing PORTAL in top
Current Version: 2.0.2
Released: 2013-10-27
seha_05
phpBB.com User: seha_05
Post by seha_05 »
Your Portal Version: 2.0.1
Boardlink: http://www.rebellions-cs.com
Hi all,
my problem is Portal link in header.
But I have it in footer.
My phpbb forum is installed in public_html folder so it is not in separated folder.
How to fix this so I have link to Portal in header like is it in footer?
P.S. Sorry for my English
Re: Missing PORTAL in top
seha_05 wrote: Boardlink: http://www.rebellions-cs.com
.....my problem is Portal link in header......
View install file B3P install.xml and edit the overall_header.html.
Then they empty the cache.
seha_05
Post by seha_05 »
Thank you bro for quick help... I fixed... :D
