Frozen Phoenix (Base: prosilver)
Style: Frozen Phoenix
Style Version: 1.6.9
Style Download: http://www.phpbb.com/customise/db/style/frozen_phoenix/
to: root/styles/frozen_phoenix/template/portal/*.*
to: root/styles/frozen_phoenix/theme/portal.css
to: root/styles/frozen_phoenix/theme/images/portal/*.*
open: root/styles/frozen_phoenix/template/breadcrumbs_footer.html
<a href="{U_INDEX}" accesskey="h">
open: root/styles/frozen_phoenix/template/breadcrumbs_main.html
open: root/styles/frozen_phoenix/template/overall_header.html
<!-- INCLUDE menu_block.html -->
		<!-- INCLUDE breadcrumbs_main.html -->
open: root/styles/frozen_phoenix/template/portal/modules/announcements_center_compact.html
{$CC_BLOCK_H_L}
	<dt id="a" <!-- IF S_DISPLAY_ANNOUNCEMENTS_RVS -->style="width: 44%"<!-- ELSE -->style="width: 60%"<!-- ENDIF -->>{$TITLE}</dt>
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
open: root/styles/frozen_phoenix/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L}
	<dt id="n" <!-- IF S_DISPLAY_NEWS_RVS -->style="width: 44%"<!-- ELSE -->style="width: 60%"<!-- ENDIF -->>{$TITLE}</dt>
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
open: root/styles/frozen_phoenix/theme/stylesheet.css
open: root/styles/frozen_phoenix/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div class="tbl"><div class="tbl-h-l" style="padding-left: 8px;"><div class="tbl-h-r"><div class="tbl-h-c"><div class="tbl-title"><span style="float: left">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</span></div></div></div></div><div class="block-main-nb"><div style="text-align: left; margin: 5px 5px 5px 5px;">' -->
<!-- DEFINE $LR_BLOCK_F_L = '</div></div><div class="tbl-f-l"><div class="tbl-f-r"><div class="tbl-f-c">' -->
<!-- DEFINE $LR_BLOCK_F_R = '</div></div></div></div>' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="tbl"><div class="tbl-h-l"><div class="tbl-h-r"><div class="tbl-h-c"><div class="tbl-title"><span style="text-align: center">' -->
<!-- DEFINE $C_BLOCK_H_R = '</span></div></div></div></div><div class="block-main-nb">' -->
<!-- DEFINE $C_BLOCK_F_L = '</div><div class="tbl-f-l"><div class="tbl-f-r"><div class="tbl-f-c">' -->
<!-- DEFINE $C_BLOCK_F_R = '</div></div></div></div>' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="tbl"><div class="tbl-h-l"><div class="tbl-h-r"><div class="tbl-h-c"><div class="tbl-title"><span style="text-align: center">' -->
<!-- DEFINE $CC_BLOCK_H_R = '</span></div></div></div></div><div class="block-main-nb">' -->
<!-- DEFINE $S_POSTBODY_TOP = 0 -->
nach: root/styles/frozen_phoenix/template/portal/*.*
nach: root/styles/frozen_phoenix/theme/portal.css
nach: root/styles/frozen_phoenix/theme/images/portal/*.*
Öffne: root/styles/frozen_phoenix/template/breadcrumbs_footer.html
Öffne: root/styles/frozen_phoenix/template/breadcrumbs_main.html
Öffne: root/styles/frozen_phoenix/template/overall_header.html
Öffne: root/styles/frozen_phoenix/template/portal/modules/announcements_center_compact.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
Öffne: root/styles/frozen_phoenix/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
Öffne: root/styles/frozen_phoenix/theme/stylesheet.css
Öffne: root/styles/frozen_phoenix/template/portal/_block_config.html
