Your Portal Version: 2.0.1
Boardlink: http://195.190.31.250/forum/portal.php
It's really just a question.
Is there anyway to add php code to a custom block?
add php code in block?
- phpBB.de User: Kirk
Re: add php code in block?
You can in the ACP as many as you want to add your own custom block.
mLgz0rn
hmm, i have enabled php for templates, dunno if that's what i need to do.Kirk wrote:You can in the ACP as many as you want to add your own custom block.
But when I try to post a php code in the custom blocks code, the block just shows up the php code in the portal site.
if have tried with both
<!-- PHP -->
code here
<!-- ENDPHP -->
and
but none of those worked
Why you removed the Copyrigth of phpBB.com?mLgz0rn wrote: Boardlink: http://195.190.31.250/forum/portal.php
Powered by phpBB® Forum Software © phpBB Group
mLgz0rn
i didnt, its removed in the theme im using.
if i swap to another theme its there
mLgz0rn
I think it's the language file that's messed up, in what language file do i find the CREDIT_LINE part?
The blocks where you have created the ACP, there will only html and bbcode.mLgz0rn wrote:hmm, i have enabled php for templates, dunno if that's what i need to do.
<!-- PHP -->
code here
<!-- ENDPHP -->
and
If you want a block with php you need to create you one according to these Instructions.
mLgz0rn
Alright thanks alotKirk wrote:The blocks where you have created the ACP, there will only html and bbcode.mLgz0rn wrote:hmm, i have enabled php for templates, dunno if that's what i need to do.
<!-- PHP -->
code here
<!-- ENDPHP -->
and
I found out what was wrong with the copyright thingy, when I updated to phpbb 3.0.11 the language file got overwritted somehow, and that messed the whole thing up.
So I just reinstalled the whole thing instead
