IS there a Portal Update Available?
Re: IS there a Portal Update Available?
Hello,
I made all the recommended changes mentioned here .
My portal is enabled in ACP and after the modifications and I have cleared Forum Cache
When I click on Portal - I am getting blank screen
Any Ideas?
Thanks
Aali
Any Ideas?
Thanks
Aali
- Valued Contributor
- phpBB.com User: Froddelaar
Thanks for your response.
I replaced my folder /forum/ext/board3 and with files in your attached zip ... but unfortunately its still blank .. here is my site
I also used to have portal.php which is returning error "No route found for "GET /portal.php""
In ACP, when I navigate to Extensions - Portal - General Settings, I see these message on top
Strict Standards: call_user_func() expects parameter 1 to be a valid callback, non-static method board3_portal_check_version::version() should not be called statically in /home/xxxx/public_html/xxxxxxxx/forum/portal/includes/functions_version_check.php on line 38
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_acp.php on line 137: Cannot modify header information - headers already sent by (output started at [ROOT]/portal/includes/functions_version_check.php:38)
Any suggestion where to debug ?
After doing all of the updates to get this to work on phpBB 3.2...
Has anyone noticed any cache problems? I am noticing on my portal page that it is not refreshing in a timely manner. For instance, the Recent Posts module is not showing the most recent posts. It is almost as if the entire page is not refreshing each time it is accessed. It showing a cached version.
What could be causing that?
My Portal page.
http://www.gopherpucklive.com/forum/portal
My Portal page.
Problem fixed!
Thank You!
- phpBB.de User: dr.house
- phpBB.com User: dr.house
I'm testing the various modules on version 3.2.1. There are many but I've seen that don't work paypal module donation.This is the error:
How to fix the error?
Board portal has always "followed "me from the old versions of phhb3 and I do not want to abandon this best and complete extension!!
Best regards.
Best regards.
Did you fill in the correct paypal email adress from your account?dr.house wrote: 25. July 2017 23:38 Hi,
Board portal has always "followed "me from the old versions of phhb3 and I do not want to abandon this best and complete extension!!![]()
Best regards.
In the admin panel / extensions / board3 portal / paypal module
hi, of course.But I noticed that even here the module does not work. I simulated a donation of 10 euros and gave me the same picture of error I posted myself. Also check it you.Solidjeuh wrote: 26. July 2017 12:41Did you fill in the correct paypal email adress from your account?dr.house wrote: 25. July 2017 23:38 Hi,
Best regards.
Regards.
That's strange, I activated the module on my site (at the bottom of the portal), and it works..dr.house wrote: 26. July 2017 14:07hi, of course.But I noticed that even here the module does not work. I simulated a donation of 10 euros and gave me the same picture of error I posted myself. Also check it you.Solidjeuh wrote: 26. July 2017 12:41Did you fill in the correct paypal email adress from your account?dr.house wrote: 25. July 2017 23:38 Hi,
Best regards.
Regards.
https://www.froddelpower.be
its due to a missing bracket in html file.dr.house wrote: 26. July 2017 14:07hi, of course.But I noticed that even here the module does not work. I simulated a donation of 10 euros and gave me the same picture of error I posted myself. Also check it you.Solidjeuh wrote: 26. July 2017 12:41Did you fill in the correct paypal email adress from your account?dr.house wrote: 25. July 2017 23:38 Hi,
Best regards.
Regards.
<option value="{b3p_donation_currency_center.VALUE">
<option value="{b3p_donation_currency_center.VALUE}">
thank you talonos.I checked the files:
donation_center.html
donation_side.html
but I cannot find the line that needs to be corrected.
donation_side.html
its in:dr.house wrote: 26. July 2017 17:09 thank you talonos.I checked the files:
donation_side.html
/ext/board3/portal/styles/prosilver/template/portal/modules/donation_center.html
on line: 24
and
/ext/board3/portal/styles/prosilver/template/portal/modules/donation_side.html
on line: 18
thank you Solidjeuh now it's perfectSolidjeuh wrote: 26. July 2017 17:29its in:dr.house wrote: 26. July 2017 17:09 thank you talonos.I checked the files:
donation_side.html
on line: 24
and
on line: 18
