First of all huge thank you for the portal, it's amazing!
I have trouble with link to the portal, plus some other links (FAQ etc). With rewrite turned on, they don't work at all, even though rewrite should be fine on the server, also in .htaccess. After turning off rewrite in the phpbb settings, the addresses are interpreted correctly, but they still don't work correctly, see https://www.bechlinska.cz/app.php/portal
On the other hand, the link https://www.bechlinska.cz/app.php points to the portal directly and everything works in flying colours.
Any ideas please? Thanks in advance.
link to ./app.php/portal not working
idany
- phpBB.de User: Kirk
Re: link to ./app.php/portal not working
If it doesn't work with URL rewriting, you need to contact your provider.
