[DEV] Topic Calendar Block (livewiremods.com)
As a topic calendar mod is already in beta stage, we've made a block for the portal for it.
The minicalendar is made with ajax, so the portal won't be reloaded if you swap through the months.
You need to have the Topic Calendar Mod from livewiremods.com installed, if you want to use this block.
Direct link to the actual versions and testing forums:
http://www.livewiremods.com/mods/viewforum.php?f=1
Please note: you have to be registered to be able to download and test the calendar. And: it is one of the first betas at this stage. But the guys are doing a great job! :)
Find more information and download here:
http://www.livewiremods.com/mods/viewto ... p=888#p888
Kevin wrote:Okay, here we go. First try.
  • dianaraes fix added
  • install instructions added
  • installer added
  • ACP management added
    For this first version with just an option to enable or disable the block. Enough space left for future options. (:P)
Let me know how it works. :)
Cheers,
Please let me know if you receive any problems with the installer, the ACP management or the install instructions, as i did those things.
calendar_block_board3portal_v1.0.0b3.2.zip
(84.65 KiB) Downloaded 1406 times
Re: [DEV] Topic Calendar Block (livewiremods.com)
Block update:
Kevin wrote:Package updated: http://www.livewiremods.com/mods/viewto ... p=888#p888
  • add: option to enable / disable birthdays in the block
  • add: option to enable / disable upcoming events in the block
  • add: option to enable / disable the mini calendar in the block
  • template adaptions
  • added fix for the calendar block dates
  • updater / installer updated
  • Style fix - removed rounded corners within the block
Demo: http://www.ostpocken.de/portal.php
Are those rounded corners intended or not?
If you want to remove them, just try this:
Open root/styles/prosivler/template/portal/block/calendar.html
Find:
<div class="panel bg2" id="bday-panel">
Replace with:
					<div class="inner"><span class="corners-top3"><span></span></span>
Find:
						            {L_NO_UPCOMING_BIRTHDAYS}
Replace with:
					<span class="corners-bottom3"><span></span></span>
Regards, Marc.
P.S: Ich hätte es jetzt auch in Deutsch schreiben können, bloß passt das Englische mehr zum Thema. ;)
Marc wrote:Are those rounded corners intended or not?
No, they aren't. Package updated, thank you for the fix! :D
Please note that this block is not valid XHTML strict! at this stage.
the.ronin
Post by the.ronin »
Which calendar mod does this mod work with?
Is it this one? http://www.phpbb.com/community/viewtopi ... 0&t=666195
No, it's a topic calendar, i've been waiting for all the time. In my opinion the best solution for a board calendar.
You'll find it following the link mentioned in my first post:
Kevin wrote:Find more information and download here:
Kevin wrote:A quick update:
Kevin wrote:*UPDATE 19.11.2008*
  • add: $user->format_date function call for event dates (solving language and time formatting problems)
  • add: get_username_string function call for usernames (birthday), group colors will now be displayed properly
  • style: tiny rework and removed over 40 XHTML validation errors (still 5 left)
Just replace the calendar.php and calendar.html with those of the updated package.
Anyone an idea how to fix the last five validation errors?
airsoftpacific
Post by airsoftpacific »
Ah, nice, I've been waiting for this one. Thanks!
delirium
Post by delirium »
hey
I got a little problem with this mod:
[phpBB Debug] PHP Notice: in file /portal/block/calendar.php on line 48: include_once(./includes/functions_calendar.php) [function.include-once]: failed to open stream: No such file or directory
[phpBB Debug] PHP Notice: in file /portal/block/calendar.php on line 48: include_once() [function.include]: Failed opening './includes/functions_calendar.php' for inclusion (include_path='.:.:.:.:/usr/share/php5:/usr/share/php5/PEAR')
I could not find the requested file "functions_calender.php" in the file package.
thanks for answers
You need to install the topic calendar mod itself first, in order to run this block:
Kevin wrote:No, it's a topic calendar, i've been waiting for all the time. In my opinion the best solution for a board calendar.
delirium
Post by delirium »
I did install it via "/install_tcb/..." and it also appears in mod list...
Okay, once again, we have two parts:
  • The Topic Calendar Mod itself, which is the main mod and adds a complete calendar to your board (completely independent from the portal). You can assign topics as events to this calendar.
    You need to download this mod from livewiremods.com (calendar mod 1.0.0b3 phpBB3.zip) and install it to your forum. After that you have to install the 1.0.0b3+ [phpBB3 & SGP040] Fix Compilation.
  • The topic calendar block for Board3 Portal (we are talking about in this topic). It only works if you have the main mod (calendar) installed.
Please note: i don't recommend to install this for admins with basic knowledge. The topic calendar mod is still in a early beta stage, the block for the Board3 Portal is in early Dev stage.
And it's a bit tricky to install the topic calendar mod, including the fix compilation at this time. A lot of editing needs to be done and you have to get a lot of information together.
So i would recommend to wait until both - the main mod and the portal block - are more completed.
Got it? ;)
Onetimer
Post by Onetimer »
Will this block be updated to work with 1.0.3?
I desperatly need a calendar block for my portal, but after the update I don't know of any workable solutions.
Yes, it will be updated.
