Problem with poll module
Liam Davis
phpBB.de User: Liam Davis
phpBB.com User: Liam Davis
Post by Liam Davis »
Get this in view topic with poll module enabled, any fix please ?
https://i.ibb.co/4pn0zR2/Capture.png
Re: Problem with poll module
The picture does not show the poll module.
What phpBB version and what style (download link) are you using?
Liam Davis
Thanks for answer. Version is 3.3.4 style is prosilver and ne-blackgreen
Reason: Removed unnecessary full quote
Liam Davis
This is how the poll looks in the topic which it was created..
This is how it looks in all other topics
When I try to set the poll for forums in the block module the poll disappears.
Polls are only shown in the topic where it was created.
Liam Davis
Yes but mine are not...They are trying to be displayed in the other topics which is where this is coming from..
Its only happening with the portal poll module enabled.
Is there anyway to reinstall just the poll part of board3, Maybe that will fix it ?
You don't always have to answer with a full quote!
That's not really possible, the poll module can only be displayed sideways in a topic. A link to your board would be helpful.
You can reset the module to the default settings.
Liam Davis
Reset did not fix.
Board is on local xampp not published on live server yet, thanks for your time anyway.
Liam Davis
If I move the portal poll block to the left column issue solved, right block issue returns.
You should have mentioned that this problem only occurs when this module is displayed on the right side. ;)
I can understand the problem, the solution may take some time.
Liam Davis
I only just discovered the left side working. Thanks again much appreciated.
Here is the solution
Open: root/ext/board3/portal/modules/poll.php
Find:
				'S_HAS_POLL'			=> $has_poll,
Replace with:
				'S_HAS_B3P_POLL'		=> $has_poll,
Go to Directory: root/ext/board3/portal/styles/prosilver/template/portal/modules/
Open the files: poll_center.html and poll_side.html
Find in these files:
<!-- IF S_HAS_POLL -->
Replace in these files with:
<!-- IF S_HAS_B3P_POLL -->
In the end "ACP -> General" --> purge cache It's recommended to purge your browser cache too.
Liam Davis
Worked perfectly...You sir are a star ;)
Your welcome :)
