Portal extension for 3.3.0?
justint
Post by justint »
I have two forums on 3.3.0 and because it is such a pain to upgrade I really don't want to.
Is there a version of Portal 3 that will work with 3.3.0?
Thank you
Justin
Re: Portal extension for 3.3.0?
There is an adapted version, link in my signature.
justint
Post by justint »
Thank you
serpico
Post by serpico »
Thank you 8-)
HoodieWeather
Post by HoodieWeather »
I have been GONE!! for about four years. I just got my website installed from a backup. Unfort the extensions or mods are all gone, but the posts aren't. But my portal isn't there. So.. Since the service updated the whole thing for me
3.3.3 is my newest version. I'm asking if this 3.3.0 be okay to run?
The portal works under 3.3.3
HoodieWeather
Thanks Buddy.. Since MCHAT is installed onto new board. How does one push that to the main portal page, and not index? I'm sure I'll have to code some part of the porta.
