Set Portal to be Default
Lance
Post by Lance »
For installations in phpBB 3.0.x, I was able to set portal.php to be the default page on my server. So if you navigated to www.mydomain.com/forums/ the portal would be shown.
Is there any way to do that now that portal.php is no longer used?
"Some things are false no matter how many people believe them
while others are true whether we believe them or not."
Re: Set Portal to be Default
Here we go:
  • go in the ACP - General - Board Settings - and adapt your settings accordingly:
  • navigate to the directory root/ext/board3/portal/styles/prosilver/template/event/ and delete those two files:
    overall_header_breadcrumb_prepend.html and overall_footer_breadcrumb_prepend.html
  • add to your .htaccess this:
  • purge your forum and browser cache
Then it should look and function like here.
Lance
Post by Lance »
Thanks! That did the trick.
But let me ask you: It seems like just the modification to .htaccess did the job. What is the purpose of changing the settings and deleting the files?
ETA: Never mind. I see it now.
Thanks again!
You're welcome! 😊
Neves
phpBB.com User: Neves Projects
Post by Neves »
Hi Keven
I did this but when I delete
It locks me out with errors, but if I don't delete those files it works,
it wasn't explained above, what happens if I don't delete those files ?
In the "ACP -> General" --> purge cache
Neves
Post by Neves »
Ok I'm an idiot
when it locked me out of the site i thought it also locked me out of admin. section but it doesn't
I purge cache and it works
Thanks
Berni69
phpBB.com User: Berni69
Post by Berni69 »
Hi, i did that too, but i can't go back to the portal - disapeared from the headlin. It only takes me back to the index page of the forum.
