giuseppenjnj
Posts: 3 Joined: 17. March 2014 13:08
phpBB.de User: giuseppenjnj
phpBB.com User: giuseppenjnj
Post
by giuseppenjnj » 17. March 2014 13:22
Your Portal Version: 2.0.1
Boardlink: local
none
none
I wanted to know if it was possible to add the "collapsible categories" (http://www.christianbullock.com/2011/ph ... th-cookies ) in the portal.
My _block_config.html been modified to adapt to absolution style.
<!-- DEFINE $LR_BLOCK_H_L = '<div class="catglow"><div class="cathead-m"><div class="cathead-r"><div class="cathead-l" style="min-width: 180px; border-radius: 5px 5px 3px 3px;">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</div></div></div><div class="collapsethis">' -->
<!-- DEFINE $LR_BLOCK_F_R = '</div></div><br style="clear:both" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="catglow"><div class="cathead-m"><div class="cathead-r"><div class="cathead-l">' -->
<!-- DEFINE $C_BLOCK_H_R = '</div></div></div><div class="collapsethis">' -->
<!-- DEFINE $C_BLOCK_F_R = '</div></div><br style="clear:both" />' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="catglow"><div class="cathead-m"><div class="cathead-r"><div class="cathead-l">' -->
<!-- DEFINE $CC_BLOCK_H_R = '</div></div></div><div class="collapsethis">' -->
<!-- DEFINE $BLOCK_DISTANCE = '17px' -->
<!-- DEFINE $S_POSTBODY_TOP = 0 -->
There is the possibility to implement collapsible categories?
Sorry for my bad english[/i]
Posts: 1952 Joined: 27. July 2010 18:02
Post
by Kirk » 17. March 2014 18:10
Open: root/styles/absolution/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_R = '</div></div></div><div class="trigger active"></div><div class="collapsethis">' -->
<!-- DEFINE $LR_BLOCK_F_R = '</div></div></div><br style="clear:both" />' -->
<!-- DEFINE $C_BLOCK_H_R = '</div></div></div><div class="trigger active"></div><div class="collapsethis">' -->
<!-- DEFINE $C_BLOCK_F_L = '</div>' -->
<!-- DEFINE $CC_BLOCK_H_R = '</div></div></div><div class="trigger active"></div><div class="collapsethis">' -->
Open: root/styles/absolution/template/portal/portal_body.html
Find:
<table id="portal-body" cellpadding="0" cellspacing="0" border="0" width="100%">
Find:
Add after:
$(".forumlist").collapse({show: function(){
this.animate({
opacity: 'toggle',
height: 'toggle'
}, 300);
hide : function() {
this.animate({
opacity: 'toggle',
height: 'toggle'
}, 300);
</script>
giuseppenjnj
Post
by giuseppenjnj » 17. March 2014 21:20
I do not know how to thank you, I have to ask you something else, if I wanted to also add the white boxes present in the style supernova?
viewtopic.php?f=57&t=5369
I put them in the forum already but I know how to do in the portal.
thanks for everything
Post
by Kirk » 18. March 2014 19:13
giuseppenjnj wrote: I put them in the forum already but I know how to do in the portal.
<!-- DEFINE $LR_BLOCK_H_L = '<div class="catglow"><div class="cathead-m"><div class="cathead-r"><div class="cathead-l" style="min-width: 180px; border-radius: 5px 5px 3px 3px;"><div class="cat-name"><span>' -->
<!-- DEFINE $LR_BLOCK_H_R = '</span></div></div></div></div><div class="trigger active"></div><div class="collapsethis">' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="catglow"><div class="cathead-m"><div class="cathead-r"><div class="cathead-l"><div class="cat-name"><span>' -->
<!-- DEFINE $C_BLOCK_H_R = '</span></div></div></div></div><div class="trigger active"></div><div class="collapsethis">' -->
DIY instructions: Changes to forums styles
giuseppenjnj
Post
by giuseppenjnj » 18. March 2014 19:16
Support excellent and efficient. thanks to all
grazia
Posts: 53 Joined: 28. November 2014 13:54
Post
by grazia » 6. March 2015 10:09
and for styles aero, it is possible?
Posts: 1959 Joined: 19. April 2009 21:34
Post
by archivar » 6. March 2015 11:44
grazia wrote: and for styles aero, it is possible?
No!
The styles must be compatible with the current version of phpBB!
grazia
Post
by grazia » 6. March 2015 11:54
i have aero 1.5.2
Post
by archivar » 6. March 2015 12:03
grazia wrote: i have aero 1.5.2
This topic is the "absolution" styles.
For other styles open a new topic.
grazia
Post
by grazia » 6. March 2015 12:09
ok pardon, tnk.
