Calendar off
HomeRacingWorld
- phpBB.com User: Homeracingworld
Calendar off
Boardlink: http://www.homeracingworld.us/portal.ph ... #minical39
Nothing
Checked settings in the ACP
My calendar is off one day. Showing today is Sunday.
The one here is correct.
What is wrong? What made it change?
Thanks
Nothing
Thanks
Re: Calendar off
Check it in the board settings, the date format.
If there also wrong, not the cause of the portal.
Please Inquire then at phpBB.com.
Re: Calendar off
This seems to be an issue with UTC-x offsets. I'll try to have a look at that.
HomeRacingWorld
Re: Calendar off
Thank you, I checked the board settings.
Re: Calendar off
They can say how they solved the problem?HomeRacingWorld wrote:Thank you, I checked the board settings.
HomeRacingWorld
Re: Calendar off
It is not fixed. I checked all the settings in the ACP. I reloaded the module as well, but no luck yet.
The date and time are correct at the top of my forum, only this module is off.
greybox
- phpBB.com User: greybox
Re: Calendar off
I have same problem: calendar week day is incorrect on the Portal calendar (one day off) when the user time zone is negative vs UTC. The issue is also reported here:
https://www.phpbb.com/customise/db/mod/ ... s-t_103585
I understand that Marc is working on it, let's be patient.
Re: Calendar off
This should fix the incorrect day in the calendar:
https://github.com/board3/Board3-Portal ... 8bb5c2888d
greybox
Re: Calendar off
Works fine after manual editing, thank you!!
Will there be a problem in the future upgrades using automod?
Re: Calendar off
No.
markc
Re: Calendar off
I am having this problem also. I replaced the code you provided in the post above and it is still doing it. What information would you need for further assistance?
markc
Re: Calendar off
never mind i missed a line ty for the fix
Kerrith
- phpBB.com User: Kerrith
Re: Calendar off
Marc wrote:This should fix the incorrect day in the calendar:
I too tried your fix, with a new install of phpBB 2.0.5 and Board3 Portal 2.0.1.
My problem is that when I try to go forward a month from July it skips August and jumps to Sept. Then from Sept forward it stays at Sept. Sept to Oct OK. I'm in Hawaii with no daylight savings.
Is there a whole new portal_calendar.php that I could upload and overwrite the existing one?
Otherwise the board works perfectly.
Thanks,
Kerry
Re: Calendar off
You must upgrade to phpBB v.3.0.11 for B3P v.2.0.1.Kerrith wrote: I too tried your fix, with a new install of phpBB 2.0.5 and Board3 Portal 2.0.1.
Kerrith
Re: Calendar off
My bad. I do have 3.11.
I tried https://github.com/board3/Board3-Portal ... 8bb5c2888d but kept getting lots of errors.
Am I doing the editing correctly?
$this->stamp = strtotime($date);
return ($this->stamp);
In other words, I deleted both the salmon colored highlighted string and the pink colored highlight.
I noticed that the pink doesn't include the ; is that correct?
Thanks,
Kerry
Thanks,
Kerry
