Your Portal Version: 2.0.1
I apologize if this is not the right place to post this. Please move this to the correct section, if needed.
I have an online radio station and I would like to add a block to my portal that would provide the stream links so that users could tune in from there. I did some searching, wasn't able to find anything. Can anyone help?
Radio Stream Block?
AriaSilverfyre
- phpBB.com User: AriaSilverfyre
MyLady
- Sponsor
- phpBB.de User: Scanialady
- phpBB.com User: Scanialady
Re: Radio Stream Block?
I had the same problem. I found some flash players and put them in an "custom block". You can write your stream url into the files and put the player in portal (read the manual).
e.g: ffmp3-Player (now: Muses Radio Player) and skins for it
a bigger one: Native Flash Radio - you can have a bigger one for center block or a smaller one for side block (or both)
or you can google "flash radio player"
My code for the center block and native player big example:
I hope it will help you
<script type="text/javascript" src="/radio/swfobject.js"></script>
<div id="flashcontent" style="text-align: center;">
<p>
<strong>Sorry this site have a flash based native radio and needed adobe flash 10+ support. </strong><br />
<a href="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash">Download Flash here.</a>
</p>
// <![CDATA[
var so = new SWFObject("/radio/nativeradio2big.swf", "nativeradio", "398", "130", "10", "#cccccc");
so.addParam("scale", "noscale");
so.addVariable("swfcolor", "B0C1CB");
so.addVariable("swfstreamurl", "http://s7.pop-stream.de:7160");
so.addVariable("swfpause", "1");
so.write("flashcontent");
</script>
</div> </p>
<a href="/radio/natbig.html" onclick="popup(this.href, 430, 150); return false;" title="Popup"><img src="/img/popup.png" width="64" height="24" /></a><br></div>sorry for my bad english - I'm german and google is my friend
AriaSilverfyre
That's pretty neat though not quite what I was looking for (I may still use it anyway.
). I'm looking more for something that would allow users to click an icon that corresponds to their media player of choice (ie: iTunes, Winamp, etc) to play the stream, similar to other station sites such as thecaperadio.com. I apologize if I wasn't quite clear in my first post.
