My .htaccess file doesn't work with Board3 Portal
Current Version: 2.0.2
Released: 2013-10-27
Distanasia
phpBB.com User: Distanasia
Post by Distanasia »
Your Portal Version: 2.0.1
Boardlink: http://cinemarginal.org
PHP Version: PHP5
Nothing. The problem started after I installed the portal.
I tried to edit the .htaccess file several ways, but could not solve the problem.
I searched several threads but still could not solve this problem.
My .htaccess file:
#<IfModule mod_rewrite.c>
#RewriteEngine on
#</IfModule>
<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
It doesn't work :cry:
I was using a index.html file to redirect:
window.onload = function()
window.location = 'http://mysite.org/portal.php';
</script>
But it took a while before redirect.
Can anyone help me?
Thanks in advance![/i]
Re: My .htaccess file doesn't work with Board3 Portal
Please contact your hoster. It seem like your hoster is either ignoring parts of the .htaccess or overriding its settings.
Distanasia
Ok. I'll try this. Thanks!
