Guest unable to see the portal
Current Version: 2.0.2
Released: 2013-10-27
LML
Post by LML »
Your Portal Version: 2.0.1
Boardlink: http://www.like-minded-laners.co.uk
PHP Version: 3.0.11
checked group permissions
Hi, ive recently installed Porta1 2.0.1 and i am very impressed with its flexibility and ease of use..
However i cannot get it to be seen by guests, which is the main reason i installed the MOD.
I have checked in group permissions and it is checked so they CAN see it.
Ive left the modules viewing list unchanged so all can see.
I cant think of anything else immediate to do.
Guests are blocked off completely from seeing the rest of the forum, hence the portal install
My board is here
www.like-minded-laners.co.uk and the portal IS active
Thanks for your help in advance
Re: Guest unable to see the portal
Please use the ACP to track the permissions of Guests. There is usually a reason why a specific group of users can't see the portal.
LML
Post by LML »
I have checked all permissions and they DO have access as previously stated.
In Group permission it is checked they can see portal and in the portal settings them selves, they can see portal
The only problem that has now come to mind is when installing it failed at the first hurdle stating the umil file was out of dater and couldnt install. It pointed us to a new umil file (1.0.5)
which we installed and the installation went then without a problem
Possibly this fault??
LML
Post by LML »
I have checked all in the ACP and Guest DO have access and in the module they are also allowed access
Upon install the only problem we had was it stated the umil file was out of date and could not install. It gave a link to a new umil (1.0.5). we installed that and then the portal install went ahead with no problems and all files installed successfully
could it be this?
Thanks
LML
Post by LML »
Problem solved, what an idiot i feel.
I had deleted the anonymous user (anon69) from guests group
She now works
Thank you for your continued help
Moral of the story....dont delete things panicing thinking its something its not
