Your Portal Version: 2.0.0
Boardlink: http://forumsinspain.info
I ran the upgrade from 2.0.0 to 2.0.1 and on the thrid stage of the upgrade I got the message
ERROR: Could not open the file ../styles/prosilverdrafts.html for reading. under refreshing the prosilver template.
There is no file called prosilverdrafts.html
I went back and tried to run the upgrade again but it will only let me uninstall.
I have changed the install folder name and the portal seems to be working and it says that it is 2.0.1
I have manually refreshed the prosilver template which it did without error.
I am just a bit worried in case it has donea partial install
Error on upgrade to 2.0.1
cwjs
- phpBB.de User: cwjs
- phpBB.com User: cwjs
Re: Error on upgrade to 2.0.1
You probably had a corrupted file in your cache. If the rest did not display any errors then you should be fine.
cwjs
OK thanks Marc
I really like the Portal, thank you all for continuing to update and maintain it.
Clive
Clive
