24 hour early active event calendar module
Your Portal Version: 2.0.1
Boardlink: http://eff-clan.org
Updated Board 3 to latest version: 2.0.1
Nothing
Hi guys,
It seems to show the event on the calendar 1 day earlier than set, and it leaves it on there until expiry time of the event a full 24 hours later.
Help?
Nothing
Hi guys,
Help?
Re: 24 hour early active event calendar module
It's not shown as active even but rather as current event. The exact times can be seen in the events part of the calendar. This is expected behavior.
but i had an event on 5th dec, it came active on the 4th??
It doesn't show as active. It shows as current. Any event in the next 24 hours will show as current. It still displays the time so I really don't see your problem here.
Matter of quick flash. If they see current event, they come on server. Little do they realise that it is meant for another time.
What was changed since 2.0.1 for this particular setting so im ay revert it back to only show as current within the given time frame?
The behavior was changed in this commit:
https://github.com/board3/Board3-Portal ... 1fe95cd246
wow i see ok thanks
I gotta get my thinking hat on.
Am I right in assuming that there r multiple things to change in here?>
That part is the actual change that you would need to revert:
https://github.com/board3/Board3-Portal ... 246#L0L210
From 210-213??
Yes, that code is replace with the text with green background right below that.
with that modification done, it shows up 1 hour earlier, but this is much better than before.
Thanks Marc for your help!!!
