Broken Board3 Portal - prosilver_se issue
- phpBB.de User: Kirk
Re: Broken Board3 Portal - prosilver_se issue
Look http://cyprus-forum.net/styles/prosilve ... onfig.html
copy: root/styles/prosilver/template/portal/_block_config.html
to: root/styles/prosilver_se/template/portal/_block_config.html
cpg
- Sponsor
- phpBB.de User: cpg
Seems, you have the right deal now
Cypriotmatrix
- phpBB.com User: Cypriotmatrix
OK I have done that. It has improved it. Almost there.Kirk wrote:Look http://cyprus-forum.net/styles/prosilve ... onfig.html
However some of the modules don't look right. Also the YouTube and the Weather Widgets are not centred even though {center][/center] tags have been added. What is wrong and how do I fix that?
Cypriotmatrix
Not exactly.cpg wrote:Seems, you have the right deal now
Go to the prosilver portal and see the difference. The YouTube and widgets are not centred and I can hardly read the content. Something minor is still wrong.
Cypriotmatrix
Not sute but it might have something to do with this:
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="padding: 0px 0px 2px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dt>' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' -->
<!-- DEFINE $PORTAL_RIGHT_COLUMN_OVERRIDE = '200' -->-
Your modules belong to subsilver2 and not to prosilver
You can use the portal folder in /styles/prosilver_se/template delete
Your style gets these files from prosilver.
Take for their style guide of the prosilver.Cypriotmatrix wrote:Hi,
my Board3 Portal seems to be broken.
http://cyprus-forum.net/portal.php?style=2
I do not know how to solve this issue and would like some assistance in resolving it.
So far I have tried uninstalling Board3Portal and reinstalling it but that has not worked.
Kind Regards
Replace it after the _block_config.html against this _block_config.html=>prosilver_se (Base: prosilver).
Cypriotmatrix
I don't understand what you mean.Kirk wrote:Your modules belong to subsilver2 and not to prosilver
Are you saying that I should delete /styles/prosilver_se/template?
Cypriotmatrix
So in which file do I put this code?archivar wrote:Take for their style guide of the prosilver.Cypriotmatrix wrote:Hi,
Kind Regards
<!-- DEFINE $LR_BLOCK_H_R = '</dt></dl></li></ul><ul class="topiclist forums"><li><dl><dd style="border-left: 0px; width: 100%; background-color:#ECF1F3"><div style="text-align: left; margin: 5px 5px 5px 5px">' -->
Cypriotmatrix wrote: So in which file do I put this code?
archivar wrote: Replace it after the _block_config.html against this _block_config.html=>prosilver_se (Base: prosilver).
It is wrong when they have the portal-files for subsilver2 in her stylearchivar wrote: Take for their style guide of the prosilver.
Because the basis of their style is prosilver
You need the portal-files for prosilver in her style
Cypriotmatrix
Hi,archivar wrote:Cypriotmatrix wrote: So in which file do I put this code?archivar wrote: Replace it after the _block_config.html against this _block_config.html=>prosilver_se (Base: prosilver).It is wrong when they have the portal-files for subsilver2 in her stylearchivar wrote: Take for their style guide of the prosilver.![]()
Because the basis of their style is prosilver![]()
You need the portal-files for prosilver in her style![]()
sorry for the dumb questions.
I am really lost here and don't understand what I need to do.
Can you please tell me step by step because I fear I am going to get it wrong as I don't know exactly what I am doing.
I think I have explained step by step.
Simple I can not explain them.
Please elaborate at which point you are lost.
Cypriotmatrix
Hi Marc,Marc wrote:Please elaborate at which point you are lost.
I simply do not understand what I need to do.
I was given a link that included some edits but I am worried that this will stuff it up more.
Is there a step by step or tutorial for dummies.
I had it working before but for some reason it is thinking it is subsilver2.
How do I change it to prosilver?
