General Error: Forum Not Working
Current Version: 2.0.2
Released: 2013-10-27
WendyCroft
Re: General Error: Forum Not Working
Post by WendyCroft »
It told me to copy portal/root/umil
to umil.
Where should that folder have gone?
WendyCroft
Please tell me what the correct path is, then.
That's the correct path if that folder is in your forum's root folder.
WendyCroft
Which it is, but I'm STILL getting that error, which is why I'm here pleading for help.
What is with the file it mentions, /includes/acp/auth.php?
WendyCroft
There's no such file in root/includes/acp/auth.php.
In root/includes there's only two folders, acp and trim_message.
In the acp folder there's only a folder called info. In that, there's only acp_portal.php.
I'm missing a file, it seems.
It's not in the original .zip file, either.
WendyCroft wrote:I've just updated an old installation from 1.6.0 to 2.0 at http://www.rememberthebalrog.org ......
Please try to translate these instructions with Google, because my English is very bad. :oops:
Update of B3P v.1.0.6 (and older) on B3P v.2.0.0
WendyCroft
Apparently I'm missing this file: auth.php.
Can you point me to where I can obtain it?
Minimum requirement for Board3 Portal-version: 2.0.0
php-version: php 5.+
phpBB-version: phpBB 3.0.10
WendyCroft wrote:Apparently I'm missing this file: auth.php.
root/includes/auth.php
WendyCroft wrote:Can you point me to where I can obtain it?
https://www.phpbb.com/downloads/?from=s ... c472b77593
Where is the rest of your fourm and where did you copy the portal files?
If the files you mentioned is really all you have then you are obviously missing phpBB. :?
WendyCroft
http://www.rememberthebalrog.org is the forum. I copied the files as instructed. The portal files were copied from portal/root to the places I was told to copy them. I appear to be missing a file. The forum is working, the portal is not.
http://www.rememberthebalrog.org/install/index.php 404
http://www.rememberthebalrog.org/umil/umil.php exists
http://www.rememberthebalrog.org/includes/acp/auth.php 403 & 404
I'm not sure why you'd be missing that file. You might want to contact the phpBB support for that. AFAIK this file should be needed for permission checks. :?
Additionally the template files of your current style are outdated.
WendyCroft
Well, what can I do about that? I've updated to the latest version? Is there not a simple way of doing this? It seemed simple but has turned into a total nightmare.
