How is the Clovk module time zone set?
It shows local time but want it to display Cyprus time.
If it somehow detects each users local, then that is ok.
Clock module
Cypriotmatrix
- phpBB.com User: Cypriotmatrix
- phpBB.de User: Kirk
Re: Clock module
For guests you can set it in the ACP.
Your users can change the time zone in User Control Panel.
Re: Clock module
AFAIK the clock module shows your time via javascript. As it's flash there is no way to change that from within phpBB3.
Cypriotmatrix
Re: Clock module
So does it display the time set at a user's PC?Kirk wrote:Sorry my mistake.
The clock displays the time that is set on the PC.
Re: Clock module
Yes.
Cypriotmatrix
Re: Clock module
Ok, that's good.Marc wrote:Yes.
playagiron
Re: Clock module
So there is no way to set it to another timezone?
Thanks!!
Thanks!!
