New Module v2.0 to include BBDKP blocks
kiwipearls
Post by kiwipearls »
I just swtiched over to Board 3 portal thinking that implementing blocks from BBDKP portal would be easy. As BBDKP portal used version 1 block types.
But seeing 2 changed over the need to modify portal.php by creating modules for blocks I am very very stuck.
I asked BBDKP for help, but they don't understand how the new version 2 works.
This is my post I posted at BBDKP:
My results so far using the Board3 v2.0 instructions are that I can get it to call the block kindaof, but I do not know how to include the php in the module. The whole idea in version 2 is that you don't edit portal.php you put your php into modules for the blocks.
/knowledge/kb_show.php?id=54
This is my module - which calls on the block.
* @package Board3 Portal v2 - Upcoming
* @ignore
if (!defined('IN_PHPBB'))
	exit;
* @package Upcoming
class portal_upcoming_module
	* top		1
	* left		2
	* center	4
	* right		8
	* bottom	16
	public $columns = 8;
	* Default modulename
	public $name = 'PORTAL_UPCOMING';
	* Default module-image:
	public $image_src = 'icon_subscribe.gif';
	* module-language file
	public $language = 'portal_upcoming_module';
	* custom acp template
	public $custom_acp_tpl = '';
	public $hide_name = false;
		global $config, $template;
		$template->assign_vars(array(
			'EXAMPLE'			=> $config['board3_configname2_' . $module_id],
				return 'upcoming_events_side.html';
		return array(
			'title'	=> 'Upcoming Raids',
			'vars'	=> array(),
	* API functions
		return true;
		return true;
And this is my block code
{$LR_BLOCK_H_L}{$LR_BLOCK_H_R}
<!-- serverstatusblock -->
<div class="panel">
<div class="inner">
		<!-- INCLUDE planner/raidplan/planner_upcoming.html -->
<!-- end serverstatus -->
As you can see under my facbook block - I have managed to do that so far.
http://senilityguild.com
But as I understand it the BBDKP portal.php has all the includes. This is where I am stuck - and I do not know what to include in the above code and where. I assume I include it somewhere here"
But the how is beyond my level of PHP.
I know this is the raidplanner code in bbdkp portal.php
if (isset($config['bbdkp_raidplanner']))
	if ($config['rp_show_portal'] == 1)
		$user->add_lang(array('mods/raidplanner'));
		if (!class_exists('rpblocks', false))
			//display the blocks
			include($phpbb_root_path . 'includes/bbdkp/raidplanner/rpblocks.' . $phpEx);
		$blocks = new rpblocks();
		$blocks->display();
I know I am almost there. I just need a lil help from brainer people :-)
I would love some help on this and I really hope someone can. I didn't think it would be this complicated.
Re: New Module v2.0 to include BBDKP blocks
You just add this code:
      $blocks->display();
Right before this:
kiwipearls
Thanks Marc.
I had tried that so many times and it failed I ened up having to do it this way:
(I know the whole point of v2 is to not edit portal.php, but for me it was the only way to get it working)
With sheer determination to get this working, I have figured it out.
You need to create the upcoming raids module.
portal/module/portal_upcoming.php
This displays the block on the right side column.
* @ignore
	exit;
* @package Upcoming
	* top		1
	* left		2
	* center	4
	* right		8
	* bottom	16
		return array(
			'vars'	=> array(),
	* API functions
		return true;
		return true;
You then need to create the block - this is a side block
yourstyle/template/portal/modules/upcoming_events_side.html
<div class="panel">
<div class="inner">
You then need to use this portal.php code
* @ignore
define('IN_PHPBB', true);
define('IN_PORTAL', true);
define('IN_BBDKP', true);
include($phpbb_root_path . 'portal/includes/constants.' . $phpEx);
$portal_root_path = PORTAL_ROOT_PATH;
include($phpbb_root_path . $portal_root_path . 'includes/functions_modules.' . $phpEx);
include($phpbb_root_path . $portal_root_path . 'includes/functions.' . $phpEx);
if(!defined("EMED_BBDKP"))
    trigger_error($user->lang['BBDKPDISABLED'], E_USER_WARNING);
if (!isset($config['bbdkp_version']))
	// THE CONFIGS AND DATABASE TABLES AREN'T INSTALLED, EXIT
    trigger_error('GENERAL_ERROR', E_USER_WARNING);
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup('mods/portal');
$user->setup('viewforum');
$user->add_lang(array('mods/dkp_common'));
* Make sure we do an isset first,
* else we will get errors if someone uninstalls the portal and forgets to remove portal.php
if (!isset($config['board3_enable']) || !$config['board3_enable'] || !$auth->acl_get('u_view_portal'))
	redirect(append_sid($phpbb_root_path . 'index.' . $phpEx));
* get initial data
$portal_modules = obtain_portal_modules();
* set up column_count array
* with this we can hide unneeded parts of the portal
$module_count = array(
	'total' 	=> 0,
	'top'		=> 0,
	'left'		=> 0,
	'center'	=> 0,
	'right'		=> 0,
	'bottom'	=> 0,
* start assigning block vars
foreach ($portal_modules as $row)
	if($row['module_status'] == B3_MODULE_DISABLED)
		continue;
	$class_name = 'portal_' . $row['module_classname'] . '_module';
	if (!class_exists($class_name))
		include("{$phpbb_root_path}{$portal_root_path}modules/portal_{$row['module_classname']}.$phpEx");
		trigger_error(sprintf($user->lang['CLASS_NOT_FOUND'], $class_name, 'portal_' . $row['module_classname']), E_USER_ERROR);
	$module = new $class_name();
	* Check for permissions before loading anything
	* the default group of a user always defines his/her permission (KISS)
	$group_ary = (!empty($row['module_group_ids'])) ? explode(',', $row['module_group_ids']) : '';
	if ((is_array($group_ary) && !in_array($user->data['group_id'], $group_ary)))
		continue;
	if ($module->language)
		$user->add_lang('mods/portal/' . $module->language);
	if ($row['module_column'] == column_string_num('left') && $config['board3_left_column'])
		$template_module = $module->get_template_side($row['module_id']);
		$template_column = 'left';
		++$module_count['left'];
	if ($row['module_column'] == column_string_num('center'))
		$template_module = $module->get_template_center($row['module_id']);
		$template_column = 'center';
		++$module_count['center'];
	if ($row['module_column'] == column_string_num('right') && $config['board3_right_column'])
		$template_column = 'right';
		++$module_count['right'];
	if ($row['module_column'] == column_string_num('top'))
		++$module_count['top'];
	if ($row['module_column'] == column_string_num('bottom'))
		++$module_count['bottom'];
	if (!isset($template_module))
		continue;
	// Custom Blocks that have been defined in the ACP will return an array instead of just the name of the template file
	if (is_array($template_module))
		$template->assign_block_vars('modules_' . column_num_string($row['module_column']), array(
			'TEMPLATE_FILE'			=> 'portal/modules/' . $template_module['template'],
			'IMAGE_SRC'			=> $phpbb_root_path . 'styles/' . $user->theme['theme_path'] . '/theme/images/portal/' . $template_module['image_src'],
			'TITLE'				=> $template_module['title'],
			'CODE'				=> $template_module['code'],
			'MODULE_ID'			=> $row['module_id'],
			'IMAGE_WIDTH'			=> $row['module_image_width'],
			'IMAGE_HEIGHT'			=> $row['module_image_height'],
			'TEMPLATE_FILE'			=> 'portal/modules/' . $template_module,
			'IMAGE_SRC'			=> $phpbb_root_path . 'styles/' . $user->theme['theme_path'] . '/theme/images/portal/' . $row['module_image_src'],
			'TITLE'				=> (isset($user->lang[$row['module_name']])) ? $user->lang[$row['module_name']] : utf8_normalize_nfc($row['module_name']),
	unset($template_module);
$module_count['total'] = sizeof($portal_modules);
// Redirect to index if there are currently no active modules
if($module_count['total'] < 1)
// Assign specific vars
// 	'S_SMALL_BLOCK'			=> true,
	'S_PORTAL_LEFT_COLUMN'	=> $config['board3_left_column_width'],
	'S_PORTAL_RIGHT_COLUMN'	=> $config['board3_right_column_width'],
	'S_LEFT_COLUMN'			=> ($module_count['left'] > 0 && $config['board3_left_column']) ? true : false,
	'S_CENTER_COLUMN'		=> ($module_count['center'] > 0) ? true : false,
	'S_RIGHT_COLUMN'		=> ($module_count['right'] > 0 && $config['board3_right_column']) ? true : false,
	'S_TOP_COLUMN'			=> ($module_count['top'] > 0) ? true : false,
	'S_BOTTOM_COLUMN'		=> ($module_count['bottom'] > 0) ? true : false,
	'S_DISPLAY_PHPBB_MENU'	=> $config['board3_phpbb_menu'],
	'B3P_DISPLAY_JUMPBOX'	=> $config['board3_display_jumpbox'],
		$blocks->display();
// Output page
page_header($user->lang['PORTAL']);
	'body' => 'portal/portal_body.html')
make_jumpbox(append_sid("{$phpbb_root_path}viewforum.$phpEx"));
page_footer();
Breakdown of my portal.php edits
add after
add before
add after
 // Output page
		$blocks->display();
You also need to define the language file:
language/en/mods/portall/portal_upcoming_module.php
* @package Board3 Portal v2 - Welcome
* DO NOT CHANGE
	exit;
	$lang = array();
// DEVELOPERS PLEASE NOTE
	'PORTAL_UPCOMING'		=> 'Upcoming Raids',
Hoepfully this helps others who swtich over to Board 3 version 2.0+
