Attachment in portal.
Current Version: 2.0.2
Released: 2013-10-27
scorpio
phpBB.de User: Scorpio
phpBB.com User: scorpiors
Post by scorpio »
Is there any chance to show attachment images in the block of portal.
Re: Attachment in portal.
You can view pictures in their own block.
Are they trying to change this code for yourself.
<a href="http://www.your site" target="_blank"><img style="width: 100%" src="http://www.your site/images/your picture" alt=""/></a>
scorpio
Post by scorpio »
it is showing only a blank picture.
You have to replace the here http://www.your site through your domain,
at http://www.your site / images / your picture puts you clean the address of the image.
scorpio
Post by scorpio »
Address of the picture I want to use is www.aquapetz.com /FishProfiles /FProfile /photo/angel.jpg
How will I use it.
Example
<a href="http://www.aquapetz.com" target="_blank"><img style="width: 100%" src="http://www.aquapetz.com/FishProfiles/FProfile/photo/angel.jpg" alt=""/></a>
scorpio
Post by scorpio »
Thanks.
It is showing a hand sign. How can I give a link for the picture so that user can jump on given topic by clicking it.
Replace this link http://www.aquapetz.com with your Topic Link
scorpio
Post by scorpio »
I have make some .jpg files of width 150 pixels. Now I want to display these files in a single row. But they are the block shows one picture in one line and also shows bigger pictures. How can I show 5 pictures in a single row with actual dimensions?
Example
<a href="your Link" target="_blank"><img src="image link" alt=""/><img src="image link" alt=""/></a>
