This MOD will put a block with random quotes in your board3 Portal above the Birthday Block.
Tested with phpBB 3.0.1 and board3 Portal 1.0.0 RC1.
Works in prosilver basead templates, i don't know about subsilver basead because i don't have it installed.
To edit or add quotes open quotes.txt in your language directory and put each quote on a new line using html to format the quotes.
Quotes Block v.1.0.0
Quotes Block
Knight Rider
Topic author - Translator
Kharon
Re: Quotes Block
debug mode:on
templates: prosilver 3.0.1
portal.php
portal.php on line 252:
ACP
*Portal > Quotes
adm/index.php
thanks
portal.php
[phpBB Debug] PHP Notice: in file /portal.php on line 252: Undefined index: portal_quotesCode: Select all
if ($portal_config['portal_quotes'])*Portal > Quotes
[phpBB Debug] PHP Notice: in file /adm/index.php on line 299: Undefined index: portal_quotes
[phpBB Debug] PHP Notice: in file /adm/index.php on line 300: Undefined index: portal_quotesCode: Select all
$key_yes = ($new[$config_key]) ? ' checked="checked"' : '';
$key_no = (!$new[$config_key]) ? ' checked="checked"' : '';thanks
