Will inline image attachments display on the portal?
magnusm
Post by magnusm »
I've been looking around for portals for a while now, and there seems to be a problem with inline attachment images displaying on the front pages of the portal when posts from a news forum are displayed on the portal. I was wondering if that is a problem in Board3portal?
tl;dr Will inline image attachments display on the portal news posts?
thanks.
Re: Will inline image attachments display on the portal?
Not yet.
Maybe we'll implement this feature before the final release, but we'll see.
magnusm
Post by magnusm »
thanks for the reply. I guess this must be pretty tricky, since no portal can get it working. :|
I'll keep looking, maybe I'll be back again :)
hewitt
Post by hewitt »
magnusm wrote:Hi,
I was asking for this before and couldn't find any. But hey, now you can do it. Check out this this topic from phpbb. Attached images can be displayed with the news. Or as a gallery too.
Cheers,
Awesome hewitt!
Many thanks for sharing this! :)
As i had a quick look: it's limited to images?
(Moved topic to: Blocks - In Development)
hewitt
Post by hewitt »
Yes, it only displays images. Such as jpg, jpeg, gif, png, bmp. Other types of images can be added on
connect
Translator
Post by connect »
Any progress?
connect
Translator
Post by connect »
I've finally managed to bring up inline attachment functionality, so happy :D
Now I'm going to post this mod here.....
connect
Translator
Post by connect »
Hope this code will bring inline attachments to your portal, guys. ;)
1. OPEN
/portal/includes/functions.php
2. FIND
$posts[$i]['bbcode_uid'] = $row['bbcode_uid'];
$len_check = $row['post_text'];
3. BEFORE ADD
// Pull attachment data
$sql2 = 'SELECT *
	FROM ' . ATTACHMENTS_TABLE . '
	WHERE `post_msg_id` = '. $row['post_id'] .'
	AND in_message = 0';
$result2 = $db->sql_query($sql2);
while ($row2 = $db->sql_fetchrow($result2))
	$attachments[] = $row2;
$db->sql_freeresult($result2);
4. FIND
$message = smiley_text($message); // Always process smilies after parsing bbcodes
5. BEFORE ADD
if (!empty($attachments))
	parse_attachments($row['forum_id'], $message, $attachments, $update_count);
Well...that's it. Please correct me if it still wont working. :geek:
Wow - that's cool, thank you very much for sharing this! :)
I'll test it soon.
Do you have already a demo of the working code?
connect
Translator
Post by connect »
Sorry, but I prefer not to share my portal address. It would not show much anyway. But this code is working for me.
This code is taken from viewtopic.php and adapted for portal view. In other words it just makes portal to treat attachments the forum natural way. The main difference is that viewtopic.php operates with an array of posts instead of one at a time.
You could search through viewtopic.php for "// Pull attachment data"
and "parse_attachments($forum_id, $message, $attachments[$row['post_id']], $update_count);"
Ice
Post by Ice »
It works, but for some odd reason the attachments are in a reverse order on the portal. :/
connect
Translator
Post by connect »
Try to play around with mysql query from Step 3.
Adding "DESC" directive may fix that problem.
P.S. I have an incremental in ACP attachment order settings.
Yes, correct. He already added it. ;)
http://board3deportal.svn.sourceforge.n ... athrev=286
Thanks again, connect, to point out this solution! :)
connect
Translator
Post by connect »
Maybe it's better to check that ACP option before mysql request?
