Problem after portal install
Current Version: 2.0.2
Released: 2013-10-27
EsOne
phpBB.com User: EsOne
Post by EsOne »
Before I explain my problem, please know I have read the knowledgebase article and checked what it told to check.
I recently installed Portal on my 3.0.11 PHPbb locally.
After manual install I go to my page, and there is a blank page waiting for me.
I cannot access any board pages (forums, galleries, etc) though I can visit the ACP.
As I said I have checked the files for a space before the first
and after the ending
. And, I also refreshed my theme and purged the cache.
Is this common, even after verifying no spaces in files?
Is there a solution?
Re: Problem after portal install
Try re-uploading the portal files and any files you edited. Also make sure all your edited files are saved as UTF8 without BOM.
EsOne
Post by EsOne »
Thanks for the reply!
No uploading. It's all ran locally on a WAMP server at the moment (I like to get everything set up and working before I set it live.) So all files are saved directly to the root folder of my localhost.
