Sorry for my funny english, but i'm french and i don't spek very well…
I would like to install several blocks of news, each one taking his source in a different forum.
I excavated well in the codes of Board3 but I did not find how to make.
The only result that I had, it is to have two forums in the same block, or two forums in two blocks, but not a forum per block.
Thx
Several news block, differents sources
- phpBB.com User: MaamuT
Hmm… Why Not ?
- Translator
- phpBB.com User: Anywhere91
Re: Several news block, differents sources
Not taking up the block news for various reasons (if I remember correctly !)
Blocks of the gate that manages permissions based forum, not the permissions from another site
Block news not only manages external rss
Alternative. Integrate an RSS feed in a frame in portal as lastRSS
Example: http://planetozh.com/blog/2004/11/magpi ... s-parsers/
Regards (and sorry for google translation !
Bonjour / Soir
Impossible a faire en reprennant le bloc news tel quel pour deux raisons (si je me souvient bien !)
Les blocs du portail ne gere que les permissions du forum sur lequel tu es, pas les permissions d'un site externe
Le bloc news ne gere pas les flux rss externe
Autre solution. Integrer un flux rss dans un cadre du portail comme lastrss ou autres
Exemple : http://planetozh.com/blog/2004/11/magpi ... s-parsers/
Cordialement
Bonjour / Soir
Cordialement
Isn't it possible to use several announcements block with different forum id's as source? Of course this would recommend that a news must be posted as announcement and not regular topic.
I'm using this solution, but only with one block/forum-ID as source:
http://portal.poison-door.net/
Hi all,
Yes it is possible, and it is very simple, when the trick is had…
It is enough to follow the example : How to edit a module file
Not to forget to rename the variables board3
By :
After, it is enough quite simply to rename the element of the function
By :
That's all, go to the Admin panel => MODs => Portal Module
Add your new module, configure, and admire it, it is as simple as that.
P.-S. : Not to forget to also modify the variable news_row to my_item_new_row in the file template.html
board3_item
board3_my_item
$template->assign_block_vars('news_row', array(
$template->assign_block_vars('my_item_news_row', array(
Hmm… Why Not ?
- phpBB.com User: beccasmandan
Hi folks,
i am having a bit of trouble with this lol
I have the portal_news.php and portal_news2.php files
portal_news.php being the original
and i have performed the edits that are mentioned in the quoted section above on this file,
well
and
i can see two different boxes on the portal page, but the both show the same content
what am i doing wrong?
can anyone help please as i am tearing my hair out lol
thanks guys
CODE: SELECT ALL
board3_item
By :
CODE: SELECT ALL
board3_my_item
CODE: SELECT ALL
By :
CODE: SELECT ALL
well
^^ that one" CODE: SELECT ALL
By :
CODE: SELECT ALL
$template->assign_block_vars('my_item_news_row', array( "
and
^^ that one both on the portal_news.php" P.-S. : Not to forget to also modify the variable news_row to my_item_new_row in the file template.html "
thanks guys
Up.
How i can do it?
I same problem, two blocks, but the same content.
How i can do it?
