Is is possible to have a block without border.
Current Version: 2.0.2
Released: 2013-10-27
scorpio
phpBB.de User: Scorpio
phpBB.com User: scorpiors
Post by scorpio »
Your Portal Version: 2.0
Boardlink: http://aquapetz.com
PHP Version: 3.0.10
Hi Everybody
Is it possible to have a block with caption border. If yes, how is it possible. Please show here step by step.
Re: Is is possible to have a block without border.
See it here: /knowledge/kb_show.php?id=45
Replace the contents of root/styles/prosilver/template/portal/_block_config.html:
<!-- DEFINE $LR_BLOCK_H_L = '<div class="panel bg3"><div class="inner"><span class="corners-top"><span></span></span><h3>' -->
<!-- DEFINE $LR_BLOCK_H_R = '</h3>' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dt>' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' -->
