Hi How can i add menu items to the navigation at the top of the page? i think it is the menu_block.html
I have tried to add the code, but it does not show in my browser?
I have tried knowledge/kb_show.php?id=16 but this is for portal v1
any help would be appreciated
regards
add menu items
ixl
- Sponsor
- phpBB.de User: IXL
- phpBB.com User: IXLUKCOM
Re: add menu items
What theme are you using? I assume you mean the top horizontal menu and not the main menu block?
To change or add in new links to the horizontal menu, you will need to edit ( I think ) the portal body html file ( I think ) in your theme.
However to add or change menu links in the main menu, you can just go via the ACP > MODS > PORTAL MODULES > ( LOOK FOR THE MENU BLOCK ) CLICK THE EDIT BUTTON ( GREEN COG ) >( SCROLL HALF WAY DOWN TO ) CLICK THE "ADD NEW NAVIGATION LINK ).
