[EN] Where can I find installation instructions?
thomas.d
phpBB.de User: thomas.d
phpBB.com User: thomas.d
Post by thomas.d »
First you will have to unpack the downloaded zip with the Board3-Portal-archive.
Please keep the folder structure of the archive.
In it's root-folder you will find both install.xml and modx.prosilver.en.xsl
Open install.xml in your browser (you don't need to open modx.prosilver.en.xsl as this file only contains style stuff for install.xml).
After opening install.xml your browser may display a warning concerning active content. You should allow the execution of active content to have the file displayed correctly.
In the top right corner of the screen you will find the option "Select Language". The file will be shown in English by default, you may change the language here. To do so you must be connected to the internet.
Now you can read which files are included in the package and where to upload them.
Also you can see which Original-phpBB-files have to be edited.
Please check the DIY-section at the lower end of the file, it contains instructions for manual edits which can not be done by the installer.
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Return to “KB-Archiv”
