Problems upgrading.
Current Version: 2.0.2
Released: 2013-10-27
pcscus55
Problems upgrading.
Post by pcscus55 »
Thanks for a nice portal, first. :)
I was upgrading from 1.0.6 to 2.0.0
I screwed up something.
I'm getting the following error codes after running install
phpBB Debug] PHP Warning: in file [ROOT]/portal/includes/functions.php on line 781: include(../portal/modules/portal_main_menu.php) [function.include]: failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/portal/includes/functions.php on line 781: include(../portal/modules/portal_main_menu.php) [function.include]: failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/portal/includes/functions.php on line 781: include() [function.include]: Failed opening '../portal/modules/portal_main_menu.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php')
Warning: Cannot modify header information - headers already sent by (output started at /home/me/public_html/bbs/includes/functions.php:3815)
in /home/fme/public_html/bbs/includes/functions.php on line 2715
I do have access to the phpbb admin panel, and the installer
cpg
Sponsor
phpBB.de User: cpg
Re: Problems upgrading.
Post by cpg »
did you follow the instructions?
Don't forget:
Delete files
    Delete adm/style/acp_portal.html
    Delete language/en/mods/additional_blocks.php
    Delete language/en/mods/info_acp_additional_blocks.php
    Delete language/en/mods/install_portal.php
    Delete language/en/mods/lang_portal.php
    Delete language/en/mods/lang_portal_acp.php
    Delete portal/block/*.*
    Delete styles/prosilver/template/portal/portal_center.html
    Delete styles/prosilver/template/portal/portal_left.html
    Delete styles/prosilver/template/portal/portal_right.html
    Delete styles/prosilver/template/portal/block/*.*
    Delete styles/prosilver/theme/images/portal/mini_cal_icon_left_arrow.png
    Delete styles/prosilver/theme/images/portal/mini_cal_icon_right_arrow.png
    Delete styles/prosilver/theme/images/portal/portal_login.png
    Delete styles/prosilver/theme/images/portal/portal_minical.png
    Delete styles/prosilver/theme/images/portal/portal_random.png
    Delete styles/prosilver/theme/images/portal/portal_stats.png
For the "header... mistake" read there (in german language; ok?): https://www.phpbb.de/kb/headers_already_sent
Best regards
CPG
ixl
Sponsor
phpBB.de User: IXL
phpBB.com User: IXLUKCOM
Post by ixl »
Just looking at the errors, I noticed that the locations are different.
Are you sure thats the actual info, or have you changed it?
I would just check ( just incase your trying to install/convert/update your install ) that you are doing this on the default themes ( make sure your forum forces your them to use default prosilver or subsilver )first before you do the install.
I recently did an upgrade from 1.0.6 to the new 2.0.0 and had no problems, but you just need to be carefull about deleting the files first, copying the new ones over, editing the files as suggested and running the install.php and then clearing your caches.
Once the portal is ok, then try setting up a custom theme.. ( if that is what your doing ).
IXL
I.X.L
Just because it worked for you, doesnt mean it's right. ;)
http://WWW.TEAMGAMERS.CO.UK
You haven't uploaded all the necessary files.
