QUESTION : POLL FOR LEFT & RIGHT COLUMN
Current Version: 2.0.2
Released: 2013-10-27
ixl
Sponsor
phpBB.de User: IXL
phpBB.com User: IXLUKCOM
Post by ixl »
Hi.
1, I just wondered what is the reason why the Poll ( Vote ) cannot be used in the left or right columns. Can anyone please advise? :) These would be great and were working in the 2.0.0b version but not in the final latest release. :(
2, Some theme Polls look really awful in the centre middle column because the vote poll result bars are not the full width of the column, so it looks quite strange. So I wondered what can we do to fix the votes to work in the left and right columns. I use Acid Tech, and they look like this image below. Can anyone help advise what I can change to make the bars longer to match the column width properly like they do in subsilver or pro silver?
https://lh4.googleusercontent.com/-0tsG ... e_bars.JPG
Thanks
IXL
I.X.L
Just because it worked for you, doesnt mean it's right. ;)
http://WWW.TEAMGAMERS.CO.UK
Elysea
phpBB.com User: Elysea
Re: QUESTION : POLL FOR LEFT & RIGHT COLUMN
Post by Elysea »
I was just looking for the same as I would really like to put the poll in one of the side blocks.
I know how to work the older template but not this one (I love this! Don't get me wrong)
ixl
Sponsor
phpBB.de User: IXL
Post by ixl »
If I find out, I'll let you know.
I think the polls on the sides would just look so much better. :)
I.X.L
ixl wrote: 1, I just wondered what is the reason why the Poll ( Vote ) cannot be used in the left or right columns. Can anyone please advise? :) These would be great and were working in the 2.0.0b version but not in the final latest release. :(
I would not recommend the survey block on the edge, because too little space!
You can here:
search in root/portal/modules/portal_poll.php
	public $columns = 21;
replace:
	public $columns = 31;
Take it for prosilver and subsilver2 the same poll_side.html
search in root/styles/subsilver2/template/portal/modules/poll_side.html
remove:
<td dir="ltr" style="text-align: left; white-space: nowrap">{POLL_LEFT_CAP_IMG}{poll_side.poll_option.POLL_OPTION_IMG}{POLL_RIGHT_CAP_IMG}</td>
ixl wrote: 2, Some theme Polls look really awful in the centre middle column because the vote poll result bars are not the full width of the column, so it looks quite strange. So I wondered what can we do to fix the votes to work in the left and right columns. I use Acid Tech, and they look like this image below. Can anyone help advise what I can change to make the bars longer to match the column width properly like they do in subsilver or pro silver?
Unfortunately I have no better solution.
search in root/styles/subsilver2/template/portal/modules/poll_center.html
<table cellspacing="0" cellpadding="2" border="0">
replace:
<table cellspacing="0" cellpadding="2" border="0" width="100%">
ixl
Sponsor
phpBB.de User: IXL
Post by ixl »
Hi Archivar
Hope you are well
Thanks for the advise, I will look at what you have suggested. :)
I will report back and let you know if this helps, so other people can use it.
:D
I.X.L
Elysea
Post by Elysea »
Thank you, I will try it tomorrow :)
I'm using prosilver and will let you know how it work.
(The poll across mid portal with the red stripes is not pretty)
ixl
Sponsor
phpBB.de User: IXL
Post by ixl »
That works perfectly for us.
Thank you so much. :D :mrgreen: :D
IXL
I.X.L
Elysea wrote: (The poll across mid portal with the red stripes is not pretty)
You can change this in for prosilver root/styles/prosilver/theme/colours.css.
Search "poll" and experiment with the color code.
Elysea
Post by Elysea »
Didn't get around to do it before now and it works perfect.
Thank you :D
noth
phpBB.com User: noth
Post by noth »
Elysea DEMO PLEASE? :P
Elysea
Post by Elysea »
noth wrote:Elysea DEMO PLEASE? :P
Sorry, didn't see this before now. Here on the portal. Site is still wip
Overtkill
phpBB.com User: Overtkill
Post by Overtkill »
Nice looking guild website! :)
-Overt.
scorpio
phpBB.de User: Scorpio
phpBB.com User: scorpiors
Post by scorpio »
After applying the given code, the center POLL will be disabled or not? I want to put a left/right POLL and a center poll. Please guide me.
