Custom Block - Add Image Question
Current Version: 2.0.2
Released: 2013-10-27
ixl
Sponsor
phpBB.de User: IXL
phpBB.com User: IXLUKCOM
Post by ixl »
Hi.
I am using :
phpBB3 3.10
Portal 2.0.0
Acidtech Theme as default. ( Force )
I'm not sure if this is supposed to happen, but if we enter our own image for the custom block the example states :
Module image:
Enter the filename of the module image. Images need to be in all styles/{yourstyle}/theme/images/portal/ folders
Which I understand. :)
So I have uploaded my image into the right place in my custom theme ( acidtech ) which is my default theme with the correct image name, HOWEVER when I click submit, it states :
The requested file could not be found: styles/prosilver/theme/images/portal/image_example.png
:shock:
Which I do not understand why its requesting it to be put into the "PROSILVER" theme, when its not the theme I have set as default. If I upload the image to the prosilver theme location, it works correct.
So my questions are:
  • 1, Do all custom block images that we want to add, HAVE to be put into the prosilver location, even if we dont use the prosilver theme or have it installed?
    2, Why can we not add custom images to the custom middle blocks?
I read the FAQ but there was nothing that I could see about this.
IXL
I.X.L
Just because it worked for you, doesnt mean it's right. ;)
http://WWW.TEAMGAMERS.CO.UK
Re: Custom Block - Add Image Question
I do not understand what they mean. :oops: My language is German.
ixl wrote:2, Why can we not add custom images to the custom middle blocks?
Is for the central blocks not provided.
ixl
Sponsor
phpBB.de User: IXL
Post by ixl »
Hi Archivar,
Sorry. My German is bad. :( lol
Does this help explain below?
I want to upload a different image to a custom block. If I upload it and put it in the correct location in my custom theme it errors. It says it cannot be found in the prosilver theme. This is strange as I am using a custom theme, which is not prosilver. I am asking if there is a problem with portal which only allows custom images for the blocks to only be put into the two standard themes.
( I tried google translator if it helps.. )
Hallo. Ich möchte ein anderes Bild zu einer benutzerdefinierten Block hochladen. Wenn ich es hochladen und steckte es in die richtige Stelle in meinem eigenes Thema, zeigt es einen Fehler. Der Fehler besagt das Bild nicht in der prosilver Thema gefunden werden. Das ist seltsam. Warum ist es zu fragen, bis das Bild im prosilver Thema sein? Ich verwende ein benutzerdefiniertes Design genannt acidtech für standardmäßig nicht der prosilver ihnen. Ich frage, ob es ein Problem mit Portal, das lässt nur eigene Bilder für die Blöcke, um nur in die beiden Standard-Themen gestellt werden.
I.X.L
ixl wrote: images for the blocks
The images must be copied in all styles with the same name.
It may be the png format is not compatible.
Show them the picture.
ixl
Sponsor
phpBB.de User: IXL
Post by ixl »
I think I have solved it.
I needed to refresh the image cache. :?
I.X.L
