The small pictures in the portal are gone
Current Version: 2.0.2
Released: 2013-10-27
RigPa
Post by RigPa »
The tiny images in front of Menu, Birthdays, Clock etc are gone.
The url is pointing at http://worldforumtrends.org/styles/art_ ... l_menu.png but there are no portal directory here. The clock is also missing but flash is installed.
Why does the icons point to non existing places?
Re: The small pictures in the portal are gone
Maybe you should upload the needed images to your style?
RigPa
Post by RigPa »
Does it mean they are not part of the installation?
No, it means that the installation only takes care of the default phpBB3 styles prosilver and subsilver2.
RigPa
Post by RigPa »
Aaahhh :-) Then I just copy from one of those thems :-)
Thanks a lot!
